Attribute Fill¶
The Attribute Fill node.¶
The Attribute Fill node sets the value for every element of the attribute with the input name to the input value.
Входы¶
- Geometry (геометрия)
Стандартный вход геометрии.
- Attribute
The name of the attribute to fill with the value. If the attribute doesn’t exist yet, it will be created.
- Value
A value of the data type to fill the attribute with.
Свойства¶
- Domain
Domain of the output attribute.
- Auto
Chooses the domain of the attribute if it exists already, otherwise it uses the Point domain.
- Point (точка)
Store the resulting attribute per point.
- Edge (Ребро)
Store the resulting attribute per edge.
- Face (Грань)
Store the resulting attribute per face.
- Face Corner
Store the resulting attribute per face corner
- Тип данных
The type of data to fill the attribute with.
Output (выход)¶
Стандартный выход геометрии.
