Separate Components Node
The Separate Components node.
The Separate Components node splits a geometry into a separate output for each type of data in the geometry.
Входы
- Геометрия
Standard geometry input.
Свойства
Этот узел не содержит свойств.
Выходы
- Mesh (Полисетка)
Mesh component of the input geometry.
- Point Cloud
Point cloud component of the input geometry.
- Curve
Curve component of the input geometry.
- Объём
Volume component of the input geometry.
- Instances
Instances component of the input geometry. Even if the instances contain geometry data with one of the other types, all instances will be added to this output. A Realize Instances Node can be added to move the data from geometry instances to their corresponding outputs.
