Instances to Points Node
The Instances to Points node generates points on origins of top-level instances.
Примечание
Top-level instances are those that are owned by the node’s input geometry. Instances owned by other instances, i.e. nested instances, are not considered by this node.
Входы
- Instances
Standard geometry input.
- Selection
The instances used to generate points. True values mean a point is created for the instance, false values mean the instance is skipped.
- Положение
Overrides the default position of generated point.
- Радиус
Controls the radius of the result points.
Свойства
Этот узел не содержит свойств.
Выходы
- Points
Standard geometry output.
