Rotate Euler Node
The Rotate Euler node.
The Rotate Euler node rotates an Euler rotation.
Inputs – Уводи
- Rotation – Обертання
The Euler rotation to rotate.
- Rotate By
Specifies how much an Euler rotation is rotated. This input is only available when the rotation type is set to Euler.
- Axis – Вісь
The axis to rotate around. This input is only available when the rotation type is set to Axis Angle.
- Angle – Кут
The angle to rotate by around the specified axis. This input is only available when the rotation type is set to Axis Angle.
Властивості – Properties
- Rotation Type
- Axis Angle – Вісь-Кут
Use separate axis and angle inputs to control the rotation.
- Euler – Ейлер
Use an Euler input to control the rotation.
- Space – Простір
- Object – Об’єкт
Rotate an Euler rotation in the evaluated object’s space.
- Локально – Local
Rotate an Euler rotation in local space.
Outputs – Виводи
The rotated Euler rotation.
