Random Value Node
Random Value node.
The Random Value node outputs a white noise like value as a Float, Integer, Vector, or Boolean field.
Inputs – Уводи
- Min – Мін
The minimum value of the range where random values are sampled from. This input is only available for Float, Integer, and Vector types.
- Max – Макс
The maximum value of the range where random values are sampled from. This input is only available for Float, Integer, and Vector types.
- Probability
The probability ratio for the random Boolean output to be True. This input is only available for Boolean types.
- ID – Ідентифікатор
An ID to drive the random number generator seed. By default, this input uses the same value as of the ID Node, which is the
idattribute of the context geometry if it exists, and otherwise the index.- Базис – Seed
A field to Seed the random number generator. This can be used to generate a different set of random values, even for two nodes with the same ID input.
Властивості – Properties
- Тип Даних – Data Type
- Float
The output will be a Float field.
- Integer
The output will be an Integer field.
- Vector – Вектор
The output will be a Vector field.
- Boolean – Булів
The output will be a Boolean field.
Outputs – Виводи
- Value – Значення
Random values as a field.
