Attribute Mix¶
Attribute Mix Node.¶
Mix attributes to creates to create a new attribute.
Đầu Vào (Inputs)¶
- Hình Học (Geometry)
Đầu vào hình học tiêu chuẩn.
- A, B
The first and second input to the mix operation. This can be an attribute name or a value.
- Kết Quả (Result)
Name of the attribute where the computed result is stored. The output attribute type is Color by default. When the result attribute exists already, its type is not changed.
Tính Chất (Properties)¶
- Kiểu Pha Trộn (Blend Type)
Operation that is performed on the inputs.
- Factor A, B
Input type for the corresponding socket.
Đầu Ra (Output)¶
Đầu ra hình học tiêu chuẩn.
