Nút Thực Thể thành Điểm (Instances to Points Node)
Instances to Points node.
The Instances to Points node generates points at the origins of top-level instances. Attributes on the instance domain are moved to the point cloud points.
Ghi chú
Top-level instances are those that are owned by the node's input geometry. Instances owned by other instances, i.e. nested instances, are not considered by this node.
Đầu Vào (Inputs)
Thực Thể (Instances)
Standard geometry input.
Lựa Chọn (Selection)
The instances used to generate points. True values mean a point is created for the instance, false values mean the instance is skipped.
Vị Trí (Position)
Overrides the default position of generated point.
Bán Kính (Radius)
Điều khiển bán kính của các điểm kết quả.
Tính Chất (Properties)
Nút này không có Tính Chất nào cả.
Đầu Ra (Outputs)
Số Điểm (Points)
Standard geometry output.
