Chế Độ Kênh Xoay Chiều (Rotate Instances Node)
The Rotate Instances node rotates geometry instances in local or global space.
The Thực Thể (Instances) page contains more information about geometry instances.
Đầu Vào (Inputs)
- Hình Học (Geometry)
Standard geometry input.
- Lựa Chọn (Selection)
Boolean field used to determine if an instance will be rotated.
- Xoay Chiều (Rotation)
The Euler rotation to rotate the instances by.
- Pivot Point (Điểm Tựa)
The position around which each instance is rotated. If the Local Space input is true, the location is relative to the initial transform of the instance.
- Local Space (Không Gian Địa Phương)
If enabled, the instances are rotated in local space. In other words, they are rotated around the axes described by the initial transform of each instance. When the input is disabled, the pivot point and rotation are specified in the local space of the modifier object.
Tính Chất (Properties)
Nút này không có Tính Chất nào cả.
Đầu Ra (Outputs)
Standard geometry output.
