Tam Giác Hóa Bề Mặt (Translate Instances Node)
Translate Instances node.
The Translate Instances node moves top-level geometry instances in local or global space.
The Thực Thể (Instances) page contains more information about geometry instances.
Đầu Vào (Inputs)
Hình Học (Geometry)
Standard geometry input.
Lựa Chọn (Selection)
Boolean field used to determine if an instance will be translated.
Dịch Chuyển/Phiên Dịch (Translation)
The vector to translate the instances by.
Local Space (Không Gian Địa Phương)
If enabled, the instances are translated relative to their initial rotation. Otherwise they are translated in the local space of the modifier object.
Tính Chất (Properties)
Nút này không có Tính Chất nào cả.
Đầu Ra (Outputs)
Hình Học (Geometry)
Standard geometry output.
