Bevel Node
Cycles Only
The Bevel shader node can be used for rendering rounded corners. Like bump mapping, this does not modify the actual geometry, only the shading is affected. Slight rounding on edges helps to capture specular highlights that you would also see in the real world.
Note that this is a very expensive shader, and may slow down renders by 20% even if there is a lot of other complexity in the scene. For that reason, we suggest to mainly use this for baking or still frame renders where render time is not as much of an issue. The Bevel modifier is a faster option when it works, but sometimes fails on complex or messy geometry.
Примечание
The Bevel node will not produce a valid result on objects that are either a Caustic caster or Caustic receiver while the scene contains a active Caustic caster, Caustic receiver, and Shadow Caustic Light.
Входы
- Radius (радиус)
Width of the bevel effect on edges.
- Normal
Normal to apply bevel on top of, to be combined with a Bump node for example.
Свойства
- Сэмплы
Number of samples to take for each shader evaluation. More samples give more accurate results, but are also slower to render. The default value of 4 works well for most cases, with any noise resolved by using more AA samples.
Выходы
- Normal
Стандартный выход нормали.
Примеры
Bevel shader bringing out specular highlights on the edges.
