Attribute Clamp¶
The Attribute Clamp node.¶
This node inputs one attribute and clamps the values and writes these to the result attribute.
Inputs – Уводи¶
- Geometry – Геометрія
Standard geometry input.
- Атрибут – Attribute
Name of the attribute that is to be clamped.
- Результат
Name of the attribute where the computed result it stored. If an attribute with this name does not exist yet, a new attribute is added. If it does exist, the values of the attribute are overridden.
- Min – Мін
Minimum value. This socket changes according to data type selected.
- Max – Макс
Maximum value. This socket changes according to data type selected.
Properties – Властивості¶
- Тип Даних – Data Type
This determines the data type of the result attribute. This also changes the Min and Max inputs to match the data type.
- Operation – Операція
This determines how the data is clamped.
- Мін Макс – Min Max
Constrain value between min and max.
- Range – Діапазон
Constrain value between min and max, swapping inputs when min is greater than max.
Вивід – Output¶
Standard geometry output.
