Attribute Combine XYZ¶
Attribute Combine XYZ Node.¶
The Attribute Combine XYZ Node combines a vector attribute from individual components.
Inputs – Уводи¶
- Geometry – Геометрія
Standard geometry input.
- X, Y, Z
The inputs to the components of the vector.
- Результат
The name of the attribute where the computed vector is stored. A new attribute with that name is added if it does not exist yet. If it does exist, the values of the existing attribute are overridden.
Примітка
The resulting vector is not normalized.
Properties – Властивості¶
- X, Y, Z
- Атрибут – Attribute
The input is a text field that expects an attribute name.
- Float
The input is a float number.
Вивід – Output¶
Standard geometry output.
