Attribute Separate XYZ¶
Attribute Separate XYZ Node.¶
The Attribute Separate XYZ Node splits a vector into its individual components.
Inputs – Уводи¶
- Geometry – Геометрія
Standard geometry input.
- Vector – Вектор
The vector to split into components. This can be an attribute name or a vector.
- Result X, Result Y, Result Z
The names of the attributes to store the components of the input vector. A new attribute with that name is added if it does not exist yet. If it does exist, the values of the existing attribute are overridden.
Properties – Властивості¶
- Type – Тип
- Атрибут – Attribute
The input is a text field that expects an attribute name.
- Vector – Вектор
The input is a vector of three float numbers.
Вивід – Output¶
Standard geometry output.
