Attribute Remove¶
The Attribute Remove node.¶
The Attribute Remove node removes a number of given attributes from each element of the given Geometry.
Inputs – Уводи¶
- Geometry – Геометрія
Standard geometry input.
- Attribute (Multi-Input)
The name of the attribute to remove. Multiple attribute can be removed at once by connecting multiple String Input nodes. Built-in attributes and attributes that don’t exist can’t be removed.
Properties – Властивості¶
Вивід – Output¶
Standard geometry output.
