Image Info Node#
The Image Info node gets information from image and animation. This can be useful to generate parameters in the geometry node for arbitrary images. Image information can be either general or frame-specific.
Inputs#
- Imagem
Source image to get parameters from.
- Quadro
Frame index for frame-specific outputs.
Propriedades#
Saídas#
- Largura
The number of pixels along the X axis. Specific to each frame.
- Altura
The number of pixels along the Y axis. Specific to each frame.
- Has Alpha
Whether the transparency channel be different from 1 for the pixels of this image frame. Specific to each frame.
- Frame Count
The number of frames in an image or video frame sequence. For a static image, always 1.
- FPS
The number of frames per second. For static image is always 0.
