Self Object Node#
Self Object node.
The Self Object node outputs the object that contains the geometry nodes modifier currently being executed. This can be used to retrieve the original transforms.
When evaluated in the Tool context, this node returns the Active object.
Nota
The geometry cannot be retrieved from this object with the Object Info Node, since its final geometry is still being evaluated.
Inputs#
Este nó não possui conectores de entrada.
Propriedades#
Saídas#
Self Object
The object currently being evaluated.
