Instance Scale Node#
The Instance Scale outputs the size of top-level instances on each axis in the local space of the modifier object.
The Instances page contains more information about geometry instances.
Inputs#
Este nó não possui conectores de entrada.
Propriedades#
Saídas#
- Escala
Vector that indicates the scale of each top-level instance.
