Instance Transform Node#
Instance Transform node.
The Instance Transform outputs the Transformation Matrix of each top-level instance in the local space of the modifier object.
The Instances page contains more information about geometry instances.
Inputs#
Este nó não possui conectores de entrada.
Propriedades#
Saídas#
Transformações
Matrix that indicates the Transformation of each top-level instance.
