Oclusão ambiente#
The Ambient Occlusion shader computes how much the hemisphere above the shading point is occluded. This can be used for procedural texturing, for example to add weathering effects to corners only.
For Cycles, this is an expensive shader and can slow down render significantly. If render time is a concern, using Pointiness from the Geometry node or baking Ambient Occlusion will result in faster renders.
Nota
- Cycles Only
- The Ambient Occlusion node will not produce a valid result when:
The object is either a Caustic caster or Caustic receiver while the scene contains an active Caustic caster, Caustic receiver, and Shadow Caustic Light.
Open Shading Language is active while using the OptiX rendering backend.
Inputs#
- Color
Tint for AO output color.
- Distância
Distance up to which other objects are considered to occlude the shading point.
- Normal
Normal used for ambient occlusion; if nothing is connected the default shading normal is used.
Propriedades#
- Amostras
Number of samples to use for ray-traced ambient occlusion sampling. Keep as low as possible for optimal performance.
- Lado interno
Detect convex rather than concave shapes, by computing occlusion inside mesh.
- Only Local Cycles Only
Only detect occlusion from the object itself, and not others.
Saídas#
- Color
Ambient occlusion with color tint.
- AO
Ambient occlusion factor without color tint.
Exemplo#
White AO shader.#
