Attribute Mix
../../../_images/modeling_geometry-nodes_attribute_attribute-mix_node.png
Attribute Mix Node.
Mix attributes to creates to create a new attribute.
Vstupy
Geometria
Štandardný vstup geometrie.
A, B
The first and second input to the mix operation. This can be an attribute name or a value.
Výsledok
Name of the attribute where the computed result is stored. The output attribute type is Color by default. When the result attribute exists already, its type is not changed.
Vlastnosti
Typ prelínania
Operation that is performed on the inputs.
Factor A, B
Input type for the corresponding socket.
Výstup
Geometria
Štandardný výstup geometrie.
