Attribute Sample Texture
../../../_images/modeling_geometry-nodes_attribute_attribute-sample-texture_node.png
Attribute Sample Texture node.
The Attribute Sample Texture node evaluates a texture for every point and stores the resulting colors in a new attribute. The mapping attribute can be anything that can be converted to a 3D vector. Typically, either the name of a UV map or the position attribute is used.
Poznámka
UV maps can only be accessed after a Point Distribute node currently. This is a limitation that will be resolved.
An Attribute Sample Texture node can be added quickly by dragging a texture data-block into the node editor.
Vstupy
Geometria
Štandardný vstup geometrie.
Mapovanie
Name of the attribute that determines where the texture is evaluated.
Výsledok
Name of the attribute where the results are stored.
Vlastnosti
Textúra
The texture the node should sample colors from.
Výstupy
Geometria
Štandardný výstup geometrie.
