Attribute Remove¶
The Attribute Remove node.¶
The Attribute Remove node removes a number of given attributes from each element of the given Geometry.
Vstupy¶
- Geometria
Štandardný vstup geometrie.
- Attribute (Multi-Input)
The name of the attribute to remove. Multiple attribute can be removed at once by connecting multiple String Input nodes. Built-in attributes and attributes that don’t exist can’t be removed.
Vlastnosti¶
Tento uzol nemá žiadne vlastnosti.
Výstup¶
- Geometria
Štandardný výstup geometrie.
