Đặt Hình Học ở Trung Tâm Cảnh
Đặt Hình Học ở Trung Tâm Cảnh.
The Delete Geometry node removes the selected part of a geometry. It behaves similarly to the Delete tool in Edit Mode. The type of elements to be deleted can be specified with the domain and mode properties.
Đầu Vào
- Hình Dạng
Standard geometry input.
- Lựa Chọn
Boolean field that is true for parts of the geometry to be deleted.
Tính Chất
- Phạm vi
The domain on which the selection field is evaluated.
- Điểm/Chấm
The selection is on the points, control points, and vertices of the geometry.
- Cạnh
The selection is on the edges of the mesh component. The other components are not modified.
- Bề Mặt
The selection is on the faces of the mesh component. The other components are not modified.
- Đường Cong Spline
The selection is on the splines in the curve component. For each spline, it will either be deleted entirely or not at all. The other components are not modified.
- Chế Độ
The type of elements to be affected. This only applies to the mesh component.
- Toàn Bộ
Vertices, edges, and faces in the selection will be deleted.
- Duy Cạch & Bề Mặt
Vertices won't be deleted, even if they are in the selection.
- Duy Bề Mặt
Only faces in the selection will be deleted.
Đầu Ra
- Hình Dạng
Standard geometry output.
