Geometry Proximity Node
The Geometry Proximity node.
The Geometry Proximity node computes the closest location on the target geometry.
Mẹo
The Nút Ánh Xạ phạm vi is often helpful to use with the distance output of this node to create a falloff with a maximum distance.
Đầu Vào
- Mục Tiêu
Standard geometry input.
- Vị trí Nguồn
The given position to calculate the closest location on the target.
Tính Chất
- Mục Tiêu Z -- Target Z
- Bề Mặt
Calculate the closest point anywhere on the faces of the target's mesh geometry.
- Cạnh
Calculate the closest point anywhere on the edges of the target's mesh geometry.
- Số Điểm
Calculate the closest point or vertex on the target geometry. This mode is usually the fastest. This mode works for both point cloud and mesh geometry, the other modes only work for meshes.
Đầu Ra
- Vị Trí
Closest location on the surface of the target mesh, or the closest point in the target point cloud in Points mode.
- Khoảng Cách
Distance (as floating-point value) from the source position to the closest location in the target.
Ví Dụ
The different modes of the node: faces, edges and points. In this example the Geometry Nodes modifier is added on the target plane. Note that the larger plane is subdivided and the smaller plane is not.
The three target element modes: faces, edges, and points.
Points distributed on a sphere used as a target for a distance used in a shader.
