Chế Độ Kênh Xoay Chiều
Bộ Điều Chỉnh Đường Cong -- Curve Modifier.
The Rotate Instances node rotates geometry instances in local or global space.
The Thực Thể page contains more information about geometry instances.
Đầu Vào
- Hình Dạng
Standard geometry input.
- Lựa Chọn
Boolean field used to determine if an instance will be rotated.
- Xoay Chiều
The Euler rotation to rotate the instances by.
- Điểm Tựa
The position around which each instance is rotated. If the Local Space input is true, the location is relative to the initial transform of the instance.
- Không Gian Địa Phương
If enabled, the instances are rotated in local space. In other words, they are rotated around the axes described by the initial transform of each instance. When the input is disabled, the pivot point and rotation are specified in the local space of the modifier object.
Tính Chất
Nút này không có Tính Chất nào cả.
Đầu Ra
- Hình Dạng
Standard geometry output.
