Nút Đoạn Phim (Convex Hull Node)
The Convex Hull node outputs a convex mesh that is enclosing all points in the input geometry.
Ghi chú
When the node is used on a geometry with instances, the algorithm will run once per instance, resulting in many convex hull meshes in the instance geometries. The Realize Instances node can be used to get a convex hull of an entire geometry.
Quan trọng
Volumes are not supported by this node, and attributes are not automatically transferred to the result.
Đầu Vào (Inputs)
- Hình Học (Geometry)
Hàm Tiêu Chuẩn.
Tính Chất (Properties)
Đầu Ra (Outputs)
- Bao Lồi (Convex Hull)
Mesh that encloses all points in the input.
