Phân Tách Xương (Separate Components Node)
The Separate Components node splits a geometry into a separate output for each type of data in the geometry.
Đầu Vào (Inputs)
- Hình Học (Geometry)
Standard geometry input.
Tính Chất (Properties)
Nút này không có Tính Chất nào cả.
Đầu Ra (Outputs)
- Mesh (Khung Lưới)
Mesh component of the input geometry.
- Point Cloud (Mây Điểm Chấm)
Point cloud component of the input geometry.
- Curve (Đường Cong)
Curve component of the input geometry.
- Âm Lượng (Volume)
Volume component of the input geometry.
- Thực Thể (Instances)
Instances component of the input geometry. Even if the instances contain geometry data with one of the other types, all instances will be added to this output. A Nút Chuyển các Thực Thể thành Đối Tượng Thật (Realize Instances Node) can be added to move the data from geometry instances to their corresponding outputs.
