Instances to Points Node#
The Instances to Points node generates points at the origins of top-level instances. Attributes on the instance domain are moved to the point cloud points.
Примітка
Top-level instances are those that are owned by the node’s input geometry. Instances owned by other instances, i.e. nested instances, are not considered by this node.
Inputs – Уводи#
- Примірники
Standard geometry input.
- Виділення
The instances used to generate points. True values mean a point is created for the instance, false values mean the instance is skipped.
- Position – Позиція
Overrides the default position of generated point.
- Radius – Радіус
Controls the radius of the result points.
Властивості#
Outputs – Виводи#
- Points – Точки
Standard geometry output.
