Index Switch Node#
Index Switch Node.
The Index Switch node outputs one of its inputs depending on an index value. Only the input that is passed through the node is computed.
Дивись також
The Menu Switch Node is similar but it exposes the choices as a menu.
Inputs – Уводи#
Index – Індекс
Determines which of the input options below will be passed through.
Item Inputs
One input is created for every menu entry. The input is used when the matching option is selected.
Властивості#
Тип
Determines the type of the data that is handled by the node.
Outputs – Виводи#
Вивід – Output
One of the inputs without any modifications.
