Bộ Điều Chỉnh Bool -- Boolean Modifier
The Mesh Boolean Node allows you to cut, subtract, and join the geometry of two inputs. This node offers the same operations as the Boolean modifier.
Nút Đường Cong Vectơ.
Đầu Vào
- Mesh -- Khung Lưới
Standard geometry input.
- Bản Thân Giao Cắt Nhau
Correctly calculates cases when one or both operands have self-intersections. This involves more calculations making the node slower.
- Dung Sai về Lỗ Hổng
Optimizes the Boolean output for Non-manifold geometry at the cost of increased computational time. Because of the performance impact, this option should only be enabled when the solver demonstrates errors with non-manifold geometry.
Tính Chất
- Thao Tác
- Giao Cắt Nhau
Produce a new geometry containing only the volume inside of both geometry 1 and geometry 2.
- Hợp Nhất
The two input meshes are joined, then any interior elements are removed.
- Hiệu
Geometry 2 is subtracted from geometry 1 (everything outside of geometry 2 is kept).
Đầu Ra
- Khung Lưới
Standard geometry output.
