Bộ Điều Chỉnh Mảng
The Array modifier creates an array of copies of the base object, with each copy being offset from the previous one in any of a number of possible ways. Vertices in adjacent copies can be merged if they are nearby, allowing smooth Subdivision Surface frameworks to be generated.
This modifier can be useful when combined with tileable meshes for quickly developing large scenes. It is also useful for creating complex repetitive shapes.
Multiple Array modifiers may be active for an object at the same time (e.g. to create complex three-dimensional constructs).
Tùy Chọn
Bộ điều chỉnh Mảng.
- Phương Phát Khít Vừa
Controls how the length of the array is determined. There are three choices, activating respectively the display of the Curve, Length or Count settings explained below:
- Khít Vừa Đường Cong
Generates enough copies to fit within the length of the curve object specified in Curve.
- Khít Vừa Chiều Dài
Generates enough copies to fit within the fixed length given by Length.
- Số Lượng Cố Định
Generates the number of copies specified in Count.
Ghi chú
Both Fit Curve and Fit Length use the local coordinate system size of the base object, which means that scaling the base object in Object Mode will not change the number of copies generated by the modifier.
Fit Length uses the local coordinate system length of the curve, which means that scaling the curve in Object Mode will not change the number of copies generated by the modifier.
Applying the scale can be useful for both.
Dịch Chuyển Tương Đối
- Hệ Số X/Y/Z
Adds a translation equal to the object's bounding box size along each axis, multiplied by a scaling factor, to the offset. X, Y and Z scaling factors can be specified.
Relative offset (0.5, 1.0 and 1.5) examples.
Dịch Chuyển Cố Định
- Khoảng cách X/Y/Z
Adds a constant translation component to the duplicate object's offset. X, Y and Z constant components can be specified.
Dịch Chuyển của Vật Thể
Adds a transformation taken from an object (relative to the current object) to the offset. It is good practice to use an empty object centered or near to the initial object. E.g. by rotating this empty a circle or helix of objects can be created.
Ví dụ về quá trình xóa.
Hội Nhập
If enabled, vertices in each copy will be merged with vertices in the next copy that are within the given Distance.
- Các bản sao Đầu và Cuối
If enabled and Merge is enabled, vertices in the first copy will be merged with vertices in the last copy, again if they are within Distance range. This is useful for circular objects.
Ví dụ về hợp nhất Bản Sao Đầu Tiên và Bản Sao Cuối Cùng.
Subdivision discontinuity caused by not merging vertices between first and last copies (First and Last Copies off).
Subdivision discontinuity eliminated by merging vertices between first and last copies (First and Last Copies on).
- Khoảng Cách
Controls the merge distance for Merge and First and Last Copies.
Các UV -- UVs
- Dịch Chuyển U/V
Shifts UVs of each new duplicate by a settable amount.
Đầu
- Nắp Đầu, Cuối
This allows either endpoints of the array to have a different mesh subsisted.
For the start: as if it was in position -1, i.e. one "array step" before the first "regular" array copy. For the end: as if it was in position n + 1, i.e. one "array step" after the last "regular" array copy.
When Merge is activated, the cap vertices within the Distance threshold will be merged.
Ghi chú
The start/end cap objects currently do not support the First and Last Copies option.
Gợi ý
Tính Toán Dịch Chuyển
The transformation applied from one copy to the next is calculated as the sum of the three different components (Relative, Constant and Object), each of which can be enabled/disabled independently of the others. This allows, for example, a relative offset of (1.0, 0.0, 0.0) and a constant offset of (0.1, 0.0, 0.0), giving an array of objects neatly spaced along the X axis with a constant 0.1 unit between them, whatever the original object's size.
Ví Dụ
A chain created from a single link. Sample blend-file.
A tentacle created with an Array Modifier followed by a Curve Modifier.
The segment in the foreground is the base mesh for the tentacle; the tentacle is capped by two specially-modeled objects deformed by the same Curve object as the main part of the tentacle. Sample blend-file.
Phân Dạng
Multi-level array animated with motion blur. |
Fractal created with multiple arrays. Sample blend-file. |
