Nút Phép Toán Lôgíc Bool trên Khung Lưới (Mesh Boolean Node)
The Mesh Boolean Node allows you to cut, subtract, and join the geometry of two inputs. This node offers the same operations as the Boolean modifier.
Mesh Boolean node.
Đầu Vào (Inputs)
Khung Lưới 1/2 (Mesh 1/2)
Standard geometry input.
Bản Thân Giao Cắt Nhau (Self Intersection)
Correctly calculates cases when one or both operands have self-intersections. This involves more calculations making the node slower.
Dung Sai về Lỗ Hổng (Hole Tolerant)
Optimizes the Boolean output for Non-manifold geometry at the cost of increased computational time. Because of the performance impact, this option should only be enabled when the solver demonstrates errors with non-manifold geometry.
Tính Chất (Properties)
Thao Tác (Operation)
Giao Cắt Nhau (Intersect)
Produce a new geometry containing only the volume inside of both geometry 1 and geometry 2.
Hợp Nhất (Union)
The two input meshes are joined, then any interior elements are removed.
Hiệu (Difference)
Geometry 2 is subtracted from geometry 1 (everything outside of geometry 2 is kept).
Đầu Ra (Output)
Mesh (Khung Lưới)
Standard geometry output.
