Nút Đặt Tô Bóng Mịn Màng (Set Shade Smooth Node)
The Set Shade Smooth node controls whether the mesh's faces look smooth in the viewport and renders. The input node for this data is the Is Shade Smooth node.
Đầu Vào (Inputs)
- Mesh (Khung Lưới)
Standard geometry input.
- Tô Bóng Mịn Màng (Shade Smooth)
When true, the selected faces will be marked to render smooth shaded. Otherwise the faces will be rendered flat shaded.
- Lựa Chọn (Selection)
Boolean input for selecting which faces will have the Shade Smooth value applied.
Tính Chất (Properties)
Nút này không có Tính Chất nào cả.
Đầu Ra (Outputs)
- Mesh (Khung Lưới)
Standard geometry output.
