Menu Switch Node#
![Menu Switch Node.](../../../_images/node-types_GeometryNodeMenuSwitch.webp)
The Menu Switch node outputs one of its inputs depending on a menu selection. Only the input that is passed through the node is computed.
See also
Inputs#
- Menu
Determines which of the input options below will be passed through.
- Item Inputs
One input is created for every menu entry. The input is used when the matching option is selected. Items can be renamed by Ctrl-LMB on the socket name or in the nodes Properties panel.
Properties#
- Type
Determines the type of the data that is handled by the node.
Outputs#
- Output
One of the inputs without any modifications.
