Mesh to Points Node#
Mesh to Points node.
The Mesh to Points node generates a point cloud from a mesh.
Inputs#
Mesh
Standard Mesh input.
Selection
The meshes used to generate a point cloud.
Position
Positions of generated points. By default, this input is the same as if the Position Node was connected.
Radius
Radii of generated points.
Properties#
Mode
Vertices:
Points are generated for each vertex.
Edges:
Points are generated for each edge, at the middle of each edge, by default.
Faces:
Points are generated for each face, at the average of all of each face’s vertices, by default.
Corners:
Points are generated for each corner. The points are all placed at the location of each corners vertex, so they will overlap by default.
Outputs#
Points
Generated point cloud.
