Split Edges Node
Split Edges node.
Like the Edge Split Modifier, the Split Edges node splits and duplicates edges within a mesh, breaking ’links’ between faces around those split edges.
Inputs
Mesh
Standard geometry input.
Selection
A standard Boolean selection input to determine which edges will be split.
Muista
Because of mesh topology requirements, sometimes more or fewer edges than are selected will be split.
Outputs
Mesh
Standard geometry output.
