Sort Elements Node
Sort Elements node.
The Sort Elements node rearranges geometry elements by changing their indices.
Inputs
Geometry
Standard geometry input.
Selection (Seleksi)
The selection of elements to sort, if left blank, all elements are sorted. Non-selected elements will keep their current indices.
Group ID
Elements with the same group ID are sorted together. If the connected socket is not a field, this socket has no effect.
Sort Weight
The sorted values used to do the reordering. If the connected socket is not a field, this socket has no effect.
Properti
Domain
The domain on which the selection and group ID fields are evaluated.
Point:
The fields are evaluated on points, control points, and vertices.
Edge:
The fields are evaluated on the edges of the mesh component.
Faces:
The fields are evaluated on the faces of the mesh component.
Spline:
The fields are evaluated on the splines in the curve component.
Instance:
The fields are evaluated on the top-level instances. Realized instances are ignored.
Outputs
Geometry
Standard geometry output.
