Blender 5.3 Manual
Logo
Blender 5.3 Manual
Memulai
  • About Blender
    • Blender's History
    • About Free Software and the GPL
    • The Blender Community
  • Installing Blender
    • Installing on Linux
    • Installing on macOS
    • Installing on Windows
    • Installing from Steam
  • Configuring Blender
    • Introduction
    • Configuring Peripherals
    • Defaults
  • Help System
Bagian-bagian
  • User Interface
    • Window System
      • Introduction
      • Splash Screen
      • Topbar
      • Workspaces
      • Status Bar
      • Areas
      • Regions
      • Tabs & Panels
    • Keymap
      • Default Keymap
      • Industry Compatible Keymap
    • UI Elements
      • Buttons
      • Input Fields
      • Menus
      • Eyedropper
      • Decorators
      • Data-Block Menu
      • List View
      • Tree View
      • Color Picker
      • Color Ramp Widget
      • Color Palette
      • Curve Widget
    • Tools & Operators
      • Tool System
      • Operators
      • Undo & Redo
      • Anotasi (Catatan)
      • Selecting
    • Nodes
      • Node Editors
      • Node Parts
      • Selecting
      • Arranging Nodes
      • Editing
      • Common Nodes
        • Output
          • Enable Output Node
        • Utilities
          • Bundle
            • Combine Bundle Node
            • Separate Bundle Node
            • Get Bundle Item Node
            • Store Bundle Item Node
            • Join Bundle Node
          • Closure
            • Closure
            • Evaluate Closure
          • Implicit Conversion
        • Layout Nodes
          • Frame Node
          • Reroute Node
      • Node Groups
  • Editors
    • 3D Viewport
      • Introduction
      • Startup Scene
      • Object Modes
      • Navigating
        • Introduction
        • Navigation
        • Fly/Walk Navigation
        • Align View
        • Perspective/Orthographic
        • Local View
        • Camera View
        • Viewpoint
        • View Regions
        • Contextual Views
      • 3D Cursor
      • Selecting Objects
      • Controls
        • Transform Orientation
        • Transform Pivot Point
          • Bounding Box Center
          • 3D Cursor
          • Individual Origins
          • Median Point
          • Active Element
        • Snapping
        • Proportional Editing
      • Display
        • Object Type Visibility
        • Viewport Gizmos
        • Viewport Overlays
        • Viewport Shading
      • Toolbar
        • Ukur
        • Add Cube
        • Add Cone
        • Add Cylinder
        • Add UV Sphere
        • Add Icosphere
      • Sidebar
        • Animation
          • Global Transform
      • Viewport Render
    • Image Editor
      • Introduction
      • Navigating
      • Sidebar
      • Overlays
      • Image Settings
      • Editing
    • UV Editor
      • Introduction
      • Navigating
      • Overlays
      • Sidebar
      • Selecting UVs
      • Controls
        • Snapping
    • Compositor
    • Texture Nodes
      • Introduction
      • Texture Nodes Types
        • Color Nodes
          • Combine Color Node
          • Invert Color Node
          • Mix Node
          • RGB Curves Node
          • Hue/Saturation/Value Node
          • Separate Color Node
        • Converter Nodes
          • Color Ramp Node
          • Distance Node
          • Math Node
          • RGB to BW Node
          • Value to Normal Node
        • Distort Nodes
          • At Node
          • Rotate Node
          • Scale Node
          • Translate Node
        • Input Nodes
          • Coordinates Node
          • Image Node
          • Texture Node
          • Time Curve Node
        • Output Nodes
          • Output Node
          • Viewer Node
        • Pattern Nodes
          • Checker Node
          • Bricks Node
        • Texture Nodes
          • Blend Node
          • Clouds Node
          • Distorted Noise Node
          • Magic Node
          • Marble Node
          • Musgrave Node
          • Noise Node
          • Stucci Node
          • Voronoi Node
          • Wood Node
        • Group
    • Geometry Node Editor
    • Shader Editor
    • Video Sequencer
      • Introduction
      • Sequencer
        • Introduction
        • Channels
        • Navigating
        • Toolbar
        • Sidebar
          • Cache
          • Proxy
        • Display
      • Pratinjau/Melihat Kembali
        • Introduction
        • Header
        • Toolbar
        • Sidebar
        • Controls
          • Pivot Point
          • Preview Snapping
        • Display
          • Display Mode
          • Gizmos
          • Overlays
      • Sequencer & Preview
    • Editor Klip Film
      • Introduction
      • Display
        • Viewport Gizmos
        • Mask Display
        • Clip Display
      • Sidebar Region
    • Dope Sheet
      • Introduction
      • Navigating
      • Display
        • Overlays
      • Editing
      • Modes
        • Action Editor
        • Shape Key Editor
        • Grease Pencil
        • Mask
      • Sidebar
    • Timeline
    • Graph Editor
      • Introduction
      • Channels
        • Introduction
        • Editing
      • F-Curves
        • Introduction
        • Editing
        • Properti
        • F-Curve Modifiers
    • Drivers Editor
    • Nonlinear Animation
      • Introduction
      • Tracks
      • Strips
      • Editing
        • Track
        • Strip
      • Sidebar
    • Text Editor
    • Python Console
    • Info Editor
    • Outliner
      • Introduction
      • Interface (Antarmuka)
      • Selecting
      • Editing
      • Penggunaan
    • Properties Editor
    • File Browser
    • Asset Browser
    • Spreadsheet
    • Preferences
      • Introduction
      • Viewport
      • Lights
      • Editing
      • Animation
      • Get Extensions
      • Add-on (Tambahan fitur)
      • Themes
      • Asset Libraries
      • Input
      • Navigation
      • Keymap
      • System
      • Save & Load
      • File Paths
      • Developer Tools
      • Experimental
  • Scenes & Objects
    • Scenes
      • Introduction
      • Scene Properties
    • Objects
      • Introduction
      • Tipe Objek
      • Object Origin
      • Selecting
      • Editing
        • Transform
          • Introduction
          • Transform Control
            • Numeric Input
            • Axis Locking
            • Precision
          • Move
          • Rotate
          • Scale
          • Move/Scale Texture Space
          • Randomize
          • Align Objects
        • Mirror
        • Clear
        • Apply
        • Snap
        • Duplicate
        • Duplicate Linked
        • Join
        • Asset
        • Parenting Objects
        • Modifiers
        • Constraints
        • Track
        • Relations
          • Make Single User
        • Link/Transfer Data
          • Link Data
          • Transfer Mesh Data
          • Transfer Mesh Data Layout
        • Shading
        • Rigid Body
        • Convert
        • Show/Hide
        • Clean Up
        • Delete
      • Properti objek
        • Transform
        • Relations
        • Collections
          • Introduction
          • Collections
        • Instancing
          • Vertices
          • Faces
          • Collection
        • Visibility
        • Viewport Display
        • Line Art
      • Tools
        • Toolbar
        • Tool Settings
        • Scale Cage
    • Collections
      • Introduction
      • Collections
  • Modeling
    • Introduction
    • Meshes
      • Introduction
      • Structure
      • Primitives
        • Mesh Plane
      • Tools
        • Toolbar
        • Tool Settings
        • Extrude Region
        • Extrude Manifold
        • Extrude to Cursor
        • Loop Cut
        • Poly Build
        • Spin
      • Selecting
        • Introduction
        • Select Mirror
        • Select Random
        • Checker Deselect
        • Select More/Less
        • Select Similar
        • Select All by Trait
        • Select Linked
        • Select Loops
        • Select Sharp Edges
        • Side of Active
        • By Attribute
      • Editing
        • Introduction
        • Mesh Operators
          • Transformation
            • Move, Rotate, Scale
            • To Sphere
            • Shear
            • Bend
            • Push/Pull
            • To Circle
            • Flatten
            • Shrink/Fatten
            • Skin Resize
            • Warp
            • Randomize
          • Mirror
          • Duplicate
          • Extrude
          • Gabungkan (Merge)
          • Split
          • Separate
          • Bisect
          • Knife Project
          • Knife Topology Tool
          • Convex Hull
          • Symmetrize
          • Snap to Symmetry
          • Normals
          • Shading
          • Weights
          • Set Attribute
          • Sort Elements
          • Clean Up
          • Deleting & Dissolving
        • Vertex Operators
          • Extrude Vertices
          • Extrude to Cursor or Add
          • Bevel
          • New Edge/Face from Vertices
          • Connect Vertex Path
          • Connect Vertex Pairs
          • Rip Vertices
          • Rip Vertices and Fill
          • Rip Vertices and Extend
          • Slide Vertices
          • Smooth Vertices
          • Smooth Vertices (Laplacian)
          • Vertex Crease
          • Blend from Shape
          • Propagate to Shapes
          • Vertex Groups
          • Hooks
          • Make Vertex Parent
        • Edge Operators
          • Extrude Edges
          • Bevel
          • Bridge Edge Loops
          • Screw
          • Subdivide
          • Subdivide Edge-Ring
          • Un-Subdivide
          • Rotate Edge
          • Edge Slide
          • Loop Cut and Slide
          • Offset Edge Slide
          • Edge Data
        • Face Operators
          • Extrude Faces
          • Extrude Faces Along Normals
          • Extrude Individual Faces
          • Inset Faces
          • Poke Faces
          • Triangulate Faces
          • Triangles to Quads
          • Solidify Faces
          • Wireframe
          • Fill
          • Grid Fill
          • Beautify Faces
          • Intersect (Knife)
          • Intersect (Boolean)
          • Weld Edges into Faces
          • Shade Smooth & Flat
          • Face Data
        • UV Operators
      • Properti
        • Object Data
        • Vertex Groups
          • Introduction
          • Vertex Groups Panel
          • Assigning a Vertex Group
          • Vertex Weights
        • Geometry Data
      • UVs
        • UVs & Texture Space
        • Unwrapping
          • Introduction
          • Seams
        • Tools
          • Toolbar
          • Rip Region
          • Grab
          • Relax
          • Pinch
        • Editing
        • Workflows
          • Layout Workflow
          • UDIMs
        • Using UV Maps
      • Mesh Analysis
      • Remeshing
    • Curves
      • Introduction
      • Structure
      • Primitives
      • Tools
        • Toolbar
        • Draw
        • Curve Pen
      • Selecting
      • Editing
        • Transform Panel
        • Curve
        • Control Points
        • Segments
        • Lain-lain
      • Properti
        • Shape
        • Geometry
        • Path Animation
        • Active Spline
      • Curve Display
    • Curves (New)
      • Structure
      • Primitives
      • Tools
        • Toolbar
        • Draw
        • Curve Pen
      • Selecting
      • Editing
        • Curves
        • Control Points
        • Segments
      • Properti
      • Curve Display
    • Surfaces
      • Introduction
      • Toolbar
      • Structure
      • Primitives
      • Selecting
      • Editing
        • Surface
        • Control Points
        • Segments
      • Properti
        • Shape
        • Transform Panel
        • Active Spline
    • Metaball
      • Introduction
      • Toolbar
      • Structure
      • Primitives
      • Editing
      • Properti
    • Text
      • Introduction
      • Selecting
      • Editing
      • Properti
    • Point Cloud
      • Tools
      • Selecting
      • Editing
      • Properti
    • Volumes
      • Introduction
      • Properti
    • Empties
    • Modifiers
      • Introduction
      • Common Modifier Options
      • Edit
        • Data Transfer Modifier
        • Mesh Cache Modifier
        • Mesh Sequence Cache Modifier
        • UV Project Modifier
        • UV Warp Modifier
        • Vertex Weight Edit Modifier
        • Vertex Weight Mix Modifier
        • Vertex Weight Proximity Modifier
      • Generate
        • Array Modifier
        • Array (Legacy) Modifier
        • Bevel Modifier
        • Boolean Modifier
        • Build Modifier
        • Curve to Tube Modifier
        • Decimate Modifier
        • Edge Split Modifier
        • Mask Modifier
        • Mesh to Volume Modifier
        • Mirror Modifier
        • Multiresolution Modifier
        • Remesh Modifier
        • Scatter on Surface Modifier
        • Screw Modifier
        • Skin Modifier
        • Solidify Modifier
        • Triangulate Modifier
        • Volume to Mesh Modifier
        • Weld Modifier
        • Wireframe Modifier
      • Deform
        • Armature Modifier
        • Cast Modifier
        • Curve Modifier
        • Displace Modifier
        • Hook Modifier
        • Laplacian Deform Modifier
        • Lattice Modifier
        • Mesh Deform Modifier
        • Shrinkwrap Modifier
        • Simple Deform Modifier
        • Smooth Modifier
        • Smooth Corrective Modifier
        • Smooth Laplacian Modifier
        • Surface Deform Modifier
        • Volume Displace Modifier
        • Warp Modifier
        • Wave Modifier
      • Normals
        • Normal Edit Modifier
        • Weighted Normal Modifier
        • Smooth By Angle Modifier
      • Physics
        • Cloth Modifier
        • Collision Modifier
        • Dynamic Paint Modifier
        • Explode Modifier
        • Fluid Modifier
        • Ocean Modifier
        • Particle Instance Modifier
        • Particle System Modifier
        • Soft Body Modifier
      • Geometry Nodes Modifier
    • Geometry Nodes
      • Introduction
      • Inspection
      • Attributes
      • Fields
      • Instances
      • Baking
      • Node-Based Tools
      • Gizmos
      • Performance
      • Input Nodes
        • Constant
          • Boolean Node
          • Collection Node
          • Color Node
          • Font Node
          • Image Node
          • Integer Node
          • Material Node
          • Menu Node
          • Object Node
          • Rotation Node
          • String Node
          • Value Node
          • Vector Node
        • Gizmo
          • Dial Gizmo
          • Linear Gizmo
          • Transform Gizmo
        • Impor
          • CSV (.csv)
          • Wavefront (.obj)
          • Stanford PLY (.ply)
          • STL (.stl)
          • Text (.txt)
          • OpenVDB (.vdb)
        • Scene
          • 3D Cursor Node
          • Active Camera Node
          • Bone Info Node
          • Camera Info Node
          • Collection Children Node
          • Collection Info Node
          • Image Info Node
          • Is Viewport Node
          • Mouse Position Node
          • Object Info Node
          • Scene Time Node
          • Self Object Node
          • Viewport Transform Node
      • Output Nodes
        • Warning Node
        • Viewer Node
      • Attribute Nodes
        • Attribute Statistic Node
        • Domain Size Node
        • Blur Attribute Node
        • Capture Attribute Node
        • Remove Named Attribute Node
        • Rename Attribute Node
        • Store Named Attribute Node
      • Geometry Nodes
        • Read
          • ID Node
          • Index Node
          • Named Attribute Node
          • Normal Node
          • Position Node
          • Radius Node
          • Selection Node
          • Active Element Node
        • Sample
          • Geometry Proximity Node
          • Index of Nearest
          • Raycast Node
          • Sample Index Node
          • Sample Nearest Node
        • Write
          • Set Geometry Name Node
          • Set ID Node
          • Set Position Node
          • Set Selection Node
        • Material Nodes
          • Replace Material Node
          • Material Index Node
          • Material Selection Node
          • Set Material Node
          • Set Material Index Node
        • Operations
          • Bake Node
          • Bounding Box Node
          • Convex Hull Node
          • Delete Geometry Node
          • Duplicate Elements Node
          • Merge by Distance Node
          • Split To Instances Node
          • Sort Elements Node
          • Transform Geometry Node
          • Separate Components Node
          • Separate Geometry Node
          • Displace Geometry Node
          • Smooth Geometry Node
        • Geometry to Instance Node
        • Join Geometry Node
        • Geometry Input Node
        • Selection Nodes
          • Box Selection Node
          • Normal Selection Node
          • Sphere Selection Node
      • Curve Nodes
        • Read
          • Curve Handle Positions Node
          • Curve Length Node
          • Curve Tangent Node
          • Curve Tilt Node
          • Endpoint Selection Node
          • Handle Type Selection Node
          • Is Spline Cyclic Node
          • Spline Length Node
          • Spline Parameter Node
          • Spline Resolution Node
        • Sample
          • Sample Curve Node
        • Write
          • Set Curve Normal Node
          • Set Curve Radius Node
          • Set Curve Tilt Node
          • Set Handle Positions Node
          • Set Handle Type Node
          • Set NURBS Order Node
          • Set NURBS Weight Node
          • Set Spline Cyclic Node
          • Set Spline Resolution Node
          • Set Spline Type Node
        • Operations
          • Curve to Mesh Node
          • Curve to Points Node
          • Fill Curve Node
          • Fillet Curve Node
          • Interpolate Curves Node
          • Resample Curve Node
          • Reverse Curve Node
          • Subdivide Curve Node
          • Trim Curve Node
        • Primitives
          • Arc Node
          • Bézier Segment Node
          • Curve Circle Node
          • Curve Line Node
          • Spiral Node
          • Quadratic Bézier Node
          • Quadrilateral Node
          • Star Node
        • Topology
          • Curve of Point Node
          • Offset Point in Curve Node
          • Points of Curve Node
      • Grease Pencil Nodes
        • Read
          • Named Layer Selection Node
        • Write
          • Set Grease Pencil Color Node
          • Set Grease Pencil Depth Node
          • Set Grease Pencil Softness Node
        • Operations
          • Merge Layers Node
      • Instances Nodes
        • Instance on Points Node
        • Instances to Points Node
        • Realize Instances Node
        • Rotate Instances Node
        • Scale Instances Node
        • Translate Instances Node
        • Set Instance Transform Node
        • Instance Bounds Node
        • Instance Reference Node
        • Instance Transform Node
        • Instance Rotation Node
        • Instance Scale Node
        • Instance on Elements Node
        • Randomize Transforms Node
      • Mesh Nodes
        • Read
          • Edge Angle Node
          • Edge Neighbors Node
          • Edge Vertices Node
          • Edges to Face Groups Node
          • Face Area Node
          • Face Group Boundaries Node
          • Face Neighbors Node
          • Face Set Node
          • Is Face Planar Node
          • Is Edge Smooth Node
          • Is Face Smooth Node
          • Mesh Island Node
          • Shortest Edge Paths Node
          • Vertex Neighbors Node
          • Edge Length Node
          • Face Corner Angle Node
          • Is Edge Boundary Node
          • Is Edge Loose Node
          • Is Edge Manifold Node
          • Is UV Split Node
        • Sample
          • Sample Nearest Surface Node
          • Sample UV Surface Node
        • Write
          • Set Face Set Node
          • Set Mesh Normal Node
          • Set Shade Smooth Node
        • Operations
          • Dual Mesh Node
          • Edge Paths to Curves Node
          • Extrude Mesh Node
          • Flip Faces Node
          • Mesh Bevel Node
          • Mesh Boolean Node
          • Mesh to Curve Node
          • Mesh to Density Grid Node
          • Mesh to Points Node
          • Mesh to SDF Grid Node
          • Mesh to Volume Node
          • Scale Elements Node
          • Split Edges Node
          • Subdivide Mesh Node
          • Subdivision Surface Node
          • Triangulate Node
        • Primitives
          • Cone Node
          • Cube Node
          • Cylinder Node
          • Grid Node
          • Icosphere Node
          • Mesh Circle Node
          • Mesh Line Node
          • UV Sphere Node
        • Topology
          • Corners of Edge Node
          • Corners of Face Node
          • Corners of Vertex Node
          • Edges of Corner Node
          • Edges of Vertex Node
          • Face of Corner Node
          • Offset Corner in Face Node
          • Vertex of Corner Node
        • UV
          • Pack UV Islands Node
          • UV Tangent Node
          • UV Unwrap Node
      • Point Nodes
        • Distribute Points in Volume
        • Distribute Points in Grid
        • Distribute Points on Faces
        • Points Node
        • Points to Curves Node
        • Points to SDF Grid
        • Points to Vertices Node
        • Points to Volume Node
        • Set Point Radius Node
      • Volume Nodes
        • Read
          • Get Named Grid Node
          • Grid Info Node
          • Voxel Index Node
        • Sample
          • Sample Grid Node
          • Sample Grid Index Node
          • Advect Grid Node
          • Grid Curl Node
          • Grid Divergence Node
          • Grid Gradient Node
          • Grid Laplacian Node
        • Write
          • Set Grid Background Node
          • Set Grid Transform Node
          • Store Named Grid Node
        • Operations
          • Grid to Mesh Node
          • Grid to Points Node
          • Volume to Mesh Node
          • SDF Grid Boolean Node
          • SDF Fillet Node
          • SDF Grid Laplacian Node
          • SDF Grid Mean Node
          • SDF Grid Mean Curvature Node
          • SDF Grid Median Node
          • SDF Grid Offset Node
          • Field to Grid Node
          • Clip Grid Node
          • Grid Dilate & Erode Node
          • Grid Mean Node
          • Grid Median Node
          • Prune Grid Node
          • Voxelize Grid Node
        • Primitives
          • Cube Grid Topology Node
          • Volume Cube Node
      • Simulation Zone
      • Color Utility Nodes
        • Blackbody Node
        • Node Gamma
        • Color Ramp Node
        • RGB Curves Node
        • Mix Color Node
      • Texture Nodes
        • Brick Texture Node
        • Checker Texture Node
        • Gabor Texture Node
        • Gradient Texture Node
        • Image Texture Node
        • Magic Texture Node
        • Musgrave Texture Node
        • Noise Texture Node
        • Voronoi Texture Node
        • Wave Texture Node
        • White Noise Texture Node
      • Utilities Nodes
        • Math
          • Bit Math Node
          • Boolean Math Node
          • Clamp Node
          • Compare Node
          • Float Curve
          • Float To Integer Node
          • Hash Value Node
          • Integer Math Node
          • Map Range Node
          • Math Node
          • Mix Node
        • Text
          • Format String Node
          • Join Strings Node
          • Match String Node
          • Replace String Node
          • Slice String Node
          • Split String Node
          • Trim String Node
          • Find in String Node
          • String Length Node
          • String to Curves Node
          • String to Value Node
          • Value to String Node
          • Node Karakter Spesial
        • Vector
          • Radial Tiling Node
          • Vector Curves Node
          • Vector Math Node
          • Vector Rotate Node
          • Combine XYZ Node
          • Mix Vector Node
          • Separate XYZ Node
          • Combine Cylindrical Node
          • Combine Spherical Node
          • Separate Cylindrical Node
          • Separate Spherical Node
        • Bundle
          • Join Bundle Node
        • Closure
          • Closure
          • Evaluate Closure
        • Field
          • Accumulate Field Node
          • Evaluate at Index Node
          • Evaluate on Domain Node
          • Field Average Node
          • Field Min & Max Node
          • Field Variance Node
        • List
          • Closure to List Node
          • Field to List Node
          • Filter List Node
          • Get List Item Node
          • List Length Node
        • Matrix
          • Combine Matrix Node
          • Combine Transform Node
          • Invert Matrix Node
          • Matrix Determinant Node
          • Matrix SVD Node
          • Multiply Matrices Node
          • Project Point Node
          • Separate Matrix Node
          • Separate Transform Node
          • Transform Direction Node
          • Transform Point Node
          • Transpose Matrix Node
        • Rotasi
          • Axes to Rotation Node
          • Axis Angle to Rotation Node
          • Euler to Rotation Node
          • Invert Rotation Node
          • Mix Rotation
          • Rotate Rotation Node
          • Rotate Vector Node
          • Rotation to Euler Node
          • Rotation to Quaternion Node
          • Quaternion to Rotation Node
        • Sound
          • Sample Sound Frequencies Node
        • Index Switch Node
        • Menu Switch Node
        • Random Value Node
        • Repeat Zone
        • Switch Node
        • Random Rotation Node
        • Deprecated
          • Align Euler to Vector Node
          • Rotate Euler Node
      • Group
      • Generate Nodes
        • Array Node
        • Curve to Tube Node
        • Scatter on Surface Node
      • Hair Nodes
        • Deformation
          • Blend Hair Curves
          • Displace Hair Curves
          • Frizz Hair Curves
          • Hair Curves Noise
          • Roll Hair Curves
          • Rotate Hair Curves
          • Shrinkwrap Hair Curves
          • Smooth Hair Curves
          • Straighten Hair Curves
          • Trim Hair Curves
        • Generation
          • Duplicate Hair Curves
          • Generate Hair Curves
          • Interpolate Hair Curves
        • Guides
          • Braid Hair Curves
          • Clump Hair Curves
          • Create Guide Index Map
          • Curl Hair Curves
        • Read
          • Info Kurva
          • Curve Root
          • Curve Segment
          • Curve Tip
          • Hair Attachment Info
        • Utility
          • Redistribute Curve Points
        • Write
          • Set Hair Curve Profile
      • Normals Nodes
        • Smooth By Angle Node Group
    • Transform
      • Introduction
      • Transform Modal Map
  • Sculpting & Painting
    • Introduction
    • Brushes
      • Introduction
      • Manage Brushes
      • Brush Settings
      • Texture & Texture Mask
      • Stroke
      • Falloff
      • Cursor
    • Selection & Visibility
    • Navigating in Paint Modes
    • Sculpting
      • Introduction
        • The Brush
        • Gesture Tools
        • Filters
        • Transforming
        • Painting
        • Adaptive Resolution
        • Cloth Sculpting
      • Brushes
        • Brush Types
          • Draw
          • Draw Sharp
          • Clay
          • Clay Strips
          • Clay Thumb
          • Layer
          • Inflate
          • Blob
          • Crease
          • Smooth
          • Plane
          • Scrape Multiplane
          • Pinch
          • Grab
          • Elastic Deform
          • Snake Hook
          • Thumb
          • Pose
          • Nudge
          • Rotate
          • Relax Slide
          • Boundary
          • Scene Project
          • Cloth
          • Density
          • Mask
          • Draw Face Sets
          • Erase Multires Displacement
          • Smear Multires Displacement
          • Paint
          • Smear
          • Blur
        • Brush Assets
      • Toolbar
      • Tools
        • Brush
        • Add Object Tools
        • Mask Gesture Tools
        • Hide Gesture Tools
        • Face Set Gesture Tools
        • Trim Gesture Tools
        • Line Project
        • Mesh Filter
        • Cloth Filter
        • Color Filter
        • Edit Face Set
        • Mask by Color
        • Transforms
      • Tool Settings
        • Brushes
          • Introduction
          • Manage Brushes
          • Brush Settings
          • Stroke
          • Falloff
          • Cursor
        • Brush Settings
          • Brush Settings
          • Texture
          • Stroke
          • Falloff
          • Cursor
        • Dyntopo
        • Remesh
        • Symmetry
        • Options
      • Controls
      • Editing
        • Sculpt
        • Mask
        • Face Sets
        • Expand
    • Texture Paint
      • Introduction
      • Brushes
      • Tool Settings
        • Texture Slots
        • Brushes
          • Introduction
          • Manage Brushes
          • Brush Settings
          • Stroke
          • Falloff
          • Cursor
        • Brush Settings
          • Texture
          • Stroke
          • Falloff
          • Cursor
        • Mask
        • Symmetry
        • Options
        • Tiling
      • Editing
    • Vertex Paint
      • Introduction
      • Brushes
      • Vertex Paint Tools
      • Tool Settings
        • Brushes
          • Introduction
          • Manage Brushes
          • Brush Settings
          • Stroke
          • Falloff
          • Cursor
        • Brush Settings
          • Texture
          • Stroke
          • Falloff
          • Cursor
        • Symmetry
      • Editing
    • Weight Paint
      • Introduction
      • Brushes
      • Weight Paint Tools
      • Tool Settings
        • Brushes
          • Introduction
          • Manage Brushes
          • Brush Settings
          • Stroke
          • Falloff
          • Cursor
        • Brush Settings
          • Stroke
          • Falloff
          • Cursor
        • Symmetry
        • Options
      • Using Vertex Groups
      • Editing
    • Curves Sculpting
      • Introduction
      • Brushes
        • Selection Paint
        • Add Curves
        • Delete Curves
        • Density Brush
        • Comb Curves
        • Snake Hook Curves
        • Grow / Shrink Curves
        • Pinch Curves
        • Puff Curves
        • Smooth Curves
        • Slide Curves
      • Common Settings
  • Grease Pencil
    • Introduction
    • Structure
    • Primitives
    • Properti
      • Properti objek
      • Data Properties
        • Layers
        • Onion Skinning
        • Settings
      • Curve Data
    • Modifiers
      • Introduction
      • Generate
        • Array Modifier
        • Build Modifier
        • Dot Dash Modifier
        • Envelope Modifier
        • Length Modifier
        • Line Art Modifier
        • Mirror Modifier
        • Multiple Strokes
        • Outline Modifier
        • Simplify Modifier
        • Subdivide Modifier
      • Deform
        • Armature Modifier
        • Hook Modifier
        • Lattice Modifier
        • Noise Modifier
        • Offset Modifier
        • Smooth Modifier
        • Thickness Modifier
      • Color
        • Hue/Saturation Modifier
        • Opacity Modifier
        • Tint Modifier
      • Edit
        • Texture Mapping Modifier
        • Time Offset Modifier
        • Vertex Weight Angle Modifier
    • Visual Effects
      • Introduction
      • Blur Visual Effect
      • Colorize Visual Effect
      • Flip Visual Effect
      • Glow Visual Effect
      • Pixelate Visual Effect
      • Rim Visual Effect
      • Shadow Visual Effect
      • Swirl Visual Effect
    • Materials
      • Properti
    • Multiframe
    • Animation
      • Introduction
      • Interpolation
      • Animation Tools
    • Object Modes
      • Draw Mode
        • Introduction
        • Brushes
          • Draw Brushes
          • Tint Brush
        • Drawing Tools
        • Tools
          • Brush Tool
          • Erase Tool
          • Fill Tool
          • Trim Tool
          • Eyedropper
          • Line Tool
          • Polyline Tool
          • Arc Tool
          • Curve Tool
          • Box Tool
          • Circle Tool
          • Interpolate
        • Tools Settings
          • Brush Asset
          • Brush Settings
          • Color
        • Stroke Placement
        • Drawing Plane
        • Drawing Operations
      • Sculpt Mode
        • Introduction
        • Sculpting Brushes
        • Sculpting Tools
        • Brush Settings
      • Edit Mode
        • Introduction
        • Selecting
        • Tools
          • Editing Tools
          • Pen
        • Grease Pencil Menu
        • Stroke Menu
        • Point Menu
      • Vertex Paint Mode
        • Introduction
        • Vertex Paint Brushes
        • Brush Settings
        • Editing
      • Weight Paint Mode
        • Introduction
        • Weight Paint Brushes
        • Tool Settings
          • Brush Settings
          • Options
        • Weights Menu
      • Object Mode
  • Animation & Rigging
    • Introduction
    • Animation Editors
    • Keyframes
      • Introduction
      • Editing
      • Keying Sets
    • Armatures
      • Introduction
      • Bones
        • Introduction
        • Bone Collections
        • Structure
        • Tools
          • Toolbar
          • Tool Settings
        • Selecting
        • Adding Bones
        • Editing
          • Introduction
          • Transform
          • Bone Roll
          • Extrude
          • Duplicate
          • Duplicate and Rename
          • Fill Between Joints
          • Split
          • Separate Bones
          • Subdivide
          • Switch Direction
          • Symmetrize
          • Penamaan
          • Parenting
          • Properti
          • Delete
        • Properti
          • Transform
          • Bendy Bones
          • Relations
          • Inverse Kinematics
          • Deform
          • Viewport Display
          • Properti Kustom
      • Properti
        • Introduction
        • Bone Collections
        • Selection Sets
        • Viewport Display
      • Structure
      • Skinning
        • Introduction
        • Armature Deform Parent
      • Posing
        • Introduction
        • Selecting
        • Editing
          • Introduction
          • Clear Transform
          • Apply
          • In-Betweens
          • Propagate
          • Copy/Paste Pose
          • Pose Library
          • Add IK to Bone
          • Remove IK
          • Flip Quats
          • Show/Hide
        • Tool Settings
        • Bone Constraints
          • Introduction
          • Spline IK
    • Lattice
    • Constraints
      • Introduction
        • Header
        • Common
        • Stack
      • Motion Tracking
        • Camera Solver Constraint
        • Follow Track Constraint
        • Object Solver Constraint
      • Transform
        • Copy Location Constraint
        • Copy Rotation Constraint
        • Copy Scale Constraint
        • Copy Transforms Constraint
        • Limit Distance Constraint
        • Limit Location Constraint
        • Limit Rotation Constraint
        • Limit Scale Constraint
        • Maintain Volume Constraint
        • Transformation Constraint
        • Transform Cache Constraint
      • Tracking (Pelacakan)
        • Clamp To Constraint
        • Damped Track Constraint
        • Locked Track Constraint
        • Spline IK Constraint
        • Stretch To Constraint
        • Track To Constraint
      • Relationship
        • Action Constraint
        • Armature Constraint
        • Child Of Constraint
        • Floor Constraint
        • Follow Path Constraint
        • Geometry Attribute Constraint
        • Pivot Constraint
        • Shrinkwrap Constraint
    • Actions
    • Drivers
      • Introduction
      • Penggunaan
      • Drivers Panel
      • Workflow & Examples
      • Troubleshooting
    • Markers
    • Shape Keys
      • Introduction
      • Shape Keys Panel
      • Workflow
    • Motion Paths
  • Physics
    • Introduction
    • Rigid Body
      • Introduction
      • Properti Rigid Body
        • Settings
        • Collisions
        • Dynamics
      • Rigid Body World
      • Rigid Body Constraints
        • Introduction
        • Tipe-tipe
          • Fixed Constraint
          • Point Constraint
          • Hinge Constraint
          • Slider Constraint
          • Piston Constraint
          • Generic Constraint
          • Generic Spring Constraint
          • Motor Constraint
      • Tips
    • Cloth
      • Introduction
      • Settings
        • Physical Properties
        • Cache
        • Shape
        • Collisions
        • Property Weights
        • Field Weights
      • Contoh
    • Soft Body
      • Introduction
      • Settings
        • Object
        • Simulation
        • Cache
        • Goal
        • Edges
        • Self Collision
        • Solver
      • Forces
        • Exterior
        • Interior
      • Collision
      • Contoh
    • Fluid
      • Introduction
      • Type
        • Domain
          • Settings
          • Gas Settings
            • Adaptive Domain
            • Noise
            • Viewport Display
          • Liquid Settings
            • Diffusion
            • Particles
            • Mesh
          • Guides
          • Collections
          • Cache
          • Field Weights
        • Flow
        • Effector
      • Materials
    • Particle System
      • Introduction
      • Particle System Panel
      • Emitter
        • Emission
        • Cache
        • Velocity
        • Rotasi
        • Physics
          • Introduction
          • Newtonian
          • Keyed
          • Boids
          • Fluid
        • Render
        • Viewport Display
        • Children
        • Force Fields
        • Vertex Groups
      • Hair
        • Introduction
        • Emission
        • Hair Dynamics
        • Render
        • Shape
        • Children
        • Viewport Display
      • Texture Influence
      • Particle Edit Mode
    • Dynamic Paint
      • Introduction
      • Brush
      • Canvas
    • Forces
      • Gravity
      • Force Fields
        • Introduction
        • Force Fields Types
          • Boid
          • Charge
          • Curve Guide
          • Drag
          • Fluid Flow
          • Force
          • Harmonic
          • Lennard-Jones
          • Magnetic
          • Texture
          • Turbulence
          • Vortex
          • Wind
    • Collision
    • Baking Physics Simulations
    • Simulation Nodes
  • Rendering
    • Introduction
    • Render Engines
      • EEVEE
        • Render Settings
          • Sampling
          • Light Paths
          • Raytracing
          • Volumes
          • Curves
          • Depth of Field
          • Motion Blur
          • Film
          • Performance
          • Grease Pencil
        • Scene Settings
        • World Settings
        • Object Settings
          • Properti objek
        • Materials
        • Light Settings
        • Light Probes
          • Sphere
          • Plane
          • Volume
        • Limitations
          • Limitations
          • Supported Nodes
      • Cycles
        • Render Settings
          • Sampling
          • Light Paths
          • Volumes
          • Subdivision
          • Curves
          • Simplify
          • Motion Blur
          • Film
          • Performance
          • Grease Pencil
        • World Settings
        • Object Settings
          • Object
          • Cameras
        • Material Settings
        • Light Settings
        • GPU Rendering
        • Render Baking
        • Optimizing Renders
          • Reducing Noise
          • Shader Nodes
        • Open Shading Language
        • Custom Camera
      • Workbench
        • Performance
        • Sampling
        • Lighting
        • Object Color
        • Options
        • Grease Pencil
        • Viewport Display
    • Cameras
    • Lights
      • Light Objects
      • Light Linking
      • World Environment
    • Materials
      • Introduction
      • Components
        • Surfaces
        • Volumes
        • Displacement
      • Assignment
      • Settings
      • Line Art
      • Legacy Textures
        • Introduction
        • Colors
        • Legacy Texture Types
          • Blend
          • Clouds
          • Distorted Noise
          • Image or Movie
          • Magic
          • Marble
          • Musgrave
          • Noise
          • Stucci
          • Voronoi
          • Wood
    • Shader Nodes
      • Introduction
      • Input
        • Constant
          • Boolean Node
          • Color Node
          • Integer Node
          • Menu Node
          • Value Node
          • Vector Node
        • Ambient Occlusion Node
        • Attribute Node
        • Bevel Node
        • Camera Data Node
        • Fresnel Node
        • Geometry Node
        • Curves Info Node
        • Layer Weight Node
        • Light Path Node
        • Object Info Node
        • Particle Info Node
        • Point Info
        • Raycast Node
        • Tangent Node
        • Texture Coordinate Node
        • UV Map Node
        • Color Attribute Node
        • Volume Info Node
        • Wireframe Node
      • Output
        • AOV Output Node
        • Material Output Node
        • Light Output Node
        • World Output Node
      • Shader
        • Add Shader
        • Background
        • Diffuse BSDF
        • Emission
        • Glass BSDF
        • Glossy BSDF
        • Hair BSDF
        • Holdout
        • Mix Shader
        • Metallic BSDF
        • Principled BSDF
        • Principled Hair BSDF
        • Principled Volume
        • Ray Portal BSDF
        • Refraction BSDF
        • Specular BSDF
        • Subsurface Scattering
        • Toon BSDF
        • Translucent BSDF
        • Transparent BSDF
        • Sheen BSDF
        • Volume Absorption
        • Volume Scatter
        • Volume Coefficients
      • Displacement
        • Bump Node
        • Displacement Node
        • Normal Map Node
        • Vector Displacement Node
      • Texture
        • Environment Texture Node
        • IES Texture Node
        • Sky Texture Node
        • Wave Texture Node
      • Color
        • Blackbody Node
        • Brightness/Contrast Node
        • Color Ramp Node
        • Node Gamma
        • Invert Color Node
        • Light Falloff Node
        • Mix Color Node
        • RGB Curves Node
        • Wavelength Node
        • RGB to BW Node
        • Shader To RGB Node
      • Utilities
        • Math Nodes
          • Clamp Node
          • Float Curve
          • Map Range Node
          • Math Node
          • Mix Node
        • Vector Nodes
          • Combine XYZ Node
          • Mix Vector Node
          • Separate XYZ Node
          • Mapping Node
          • Normal Node
          • Vector Transform Node
        • Repeat Zone
        • Closure
        • Evaluate Closure
        • Join Bundle Node
        • Menu Switch Node
        • Script Node
      • Group
    • Color Management
      • Color Spaces
      • Displays and Views
      • OpenColorIO
      • System Configuration
    • Freestyle
      • Introduction
      • Render Properties
      • View Layer Properties
        • Freestyle
        • Line Set
        • Line Style
          • Strokes
          • Color
          • Alpha
          • Thickness
          • Geometry
          • Texture
          • Line Style Modifiers
            • Color Modifiers
              • Along Stroke
              • Crease Angle
              • Curvature 3D
              • Distance from Camera
              • Distance from Object
              • Material
              • Noise
              • Tangent
            • Alpha Modifiers
              • Along Stroke
              • Crease Angle
              • Curvature 3D
              • Material
              • Noise
              • Tangent
            • Thickness Modifiers
              • Along Stroke
              • Calligraphy
              • Crease Angle
              • Curvature 3D
              • Material
              • Noise
              • Tangent
            • Geometry Modifiers
              • 2D Offset
              • 2D Transform
              • Backbone Stretcher
              • Bézier Curve
              • Blueprint
              • Guiding Lines
              • Perlin Noise 1D
              • Perlin Noise 2D
              • Polygonization
              • Sampling
              • Simplification
              • Sinus Displacement
              • Spatial Noise
              • Tip Remover
      • Material Properties
      • Python Scripting
    • View Layers & Passes
      • Introduction
      • View Layer
      • Passes
      • Filter
      • View Layer Override
    • Render Output
      • Introduction
      • Output Properties
        • Format
        • Frame Range
        • Stereoscopy
          • Introduction
          • Penggunaan
        • Output
        • Metadata
        • Post Processing
      • Audio Rendering
        • Introduction
        • Speaker Objects
      • Rendering Animations
      • Animation Player
  • Compositing
    • Introduction
    • Compositing Workspace
    • Sidebar
    • Compositor System
    • Using The Compositor
    • Image Kernels
    • Limitations
    • Compositing Nodes
      • Input Nodes
        • Constant
          • Boolean Node
          • Color Node
          • Font Node
          • Integer Node
          • Integer Vector Node
          • Menu Node
          • Normal Node
          • Object Node
          • String Node
          • Value Node
          • Vector Node
        • Blank Image Node
        • Bokeh Image Node
        • Group Input Node
        • Image Node
        • Image Info Node
        • Image Coordinates Node
        • Mask Node
        • Movie Clip Node
        • Sequencer Strip Info Node
        • String to Image Node
        • Scene
          • Camera Info Node
          • Object Info Node
          • Render Layers Node
          • Scene Time Node
          • Time Curve Node
      • Output Nodes
        • Group Output
        • Viewer Node
        • File Output Node
      • Color Nodes
        • Adjust
          • Color Balance Node
          • Color Correction Node
          • Exposure Node
          • Node Gamma
          • Hue Correct Node
          • RGB Curves Node
          • Tone Map Node
        • Alpha Convert Node
        • Alpha Over Node
        • Set Alpha Node
        • Depth Combine Node
        • Mix Color
        • Blackbody Node
        • Color Ramp Node
        • Convert Colorspace Node
        • Convert to Display Node
        • Invert Color Node
        • RGB to BW Node
      • Creative Nodes
        • Kuwahara Node
        • Pixelate Node
        • Posterize
        • Sepia Node
        • Split Toning Node
        • Tune Image Node
        • Unsharp Mask Node
      • Filter Nodes
        • Blur Filter Nodes
          • Bilateral Blur Node
          • Blur Node
          • Bokeh Blur Node
          • Defocus Node
          • Directional Blur Node
          • Vector Blur Node
        • Anti-Aliasing Node
        • Convolve Node
        • Denoise Node
        • Despeckle Node
        • Dilate/Erode Node
        • Mask To SDF Node
        • Inpaint Node
        • Filter Node
        • Glare Node
      • Keying Nodes
        • Channel Key Node
        • Chroma Key Node
        • Color Key Node
        • Color Spill Node
        • Difference Key Node
        • Distance Key Node
        • Keying Node
        • Keying Screen Node
        • Luminance Key Node
      • Mask Nodes
        • Cryptomatte Node
        • Cryptomatte Node (Legacy)
        • Box Mask Node
        • Ellipse Mask Node
        • Double Edge Mask Node
        • ID Mask Node
      • Tracking Nodes
        • Plane Track Deform Node
        • Stabilize 2D Node
        • Track Position Node
      • Texture Nodes
        • Wave Texture Node
      • Transform Nodes
        • Rotate Node
        • Scale Node
        • Transform Node
        • Translate Node
        • Corner Pin Node
        • Crop Node
        • Displace Node
        • Flip Node
        • Map UV Node
        • Lens Distortion Node
        • Movie Distortion Node
      • Utilities Nodes
        • Math Nodes
          • Clamp Node
          • Float Curve
          • Map Range Node
          • Math Node
          • Mix Node
        • Vector Nodes
          • Combine XYZ Node
          • Separate XYZ Node
          • Mix Vector Node
          • Vector Math Node
        • Matrix Utility Nodes
        • Text Utility Nodes
          • Match String Node
          • Slice String Node
          • Trim String Node
        • Levels Node
        • Normalize Node
        • Split Node
        • Switch Node
        • Index Switch Node
        • Menu Switch Node
        • Switch View Node
        • Relative To Pixel Node
        • Retime Node
      • Camera & Lens Effects Nodes
        • Chromatic Aberration Node
        • Sensor Noise Node
        • Vignette Node
      • Group
      • Layout Nodes
  • Motion Tracking & Masking
    • Movie Clip Data-Blocks
    • Motion Tracking
      • Introduction
      • Clip View
        • Introduction
        • Tracking Marker
        • Toolbar
          • Track
          • Solve
        • Selecting
        • Editing
          • Clip
          • Track
          • Reconstruction
        • Sidebar
          • Track
            • Track
            • Objects Panel
            • Plane Track
            • Camera
            • Marker
          • 2D Stabilization
            • Introduction
            • 2D Stabilization Panel
            • Workflow
          • View (Tampilan)
      • Graph View
      • Dope Sheet View
    • Masking
      • Introduction
      • S-Curves
      • Selecting
      • Editing
      • Sidebar
  • Video Editing
    • Sequencer Scene
    • Setting Your Project
      • Video Editing App Template
      • Directory Structure
    • Editing Your Project
      • Montage
        • Strips
          • Introduction
          • Strip Properties
          • Scene Strip
          • Clip Strip
          • Mask Strip
          • Movie Strip
          • Sound Strip
          • Image/Sequence Strip
          • Color Strip
          • Text Strip
          • Adjustment Layer Strip
          • Compositor Strip
          • Effect Strips
            • Multicam Selector Strip
            • Speed Control Strip
            • Glow Strip
            • Gaussian Blur Strip
            • Add Strip
            • Subtract Strip
            • Multiply Strip
            • Alpha Over & Alpha Under Strips
            • Color Mix Strip
          • Transisi
            • Sound Crossfade
            • Cross Strip
            • Gamma Cross Strip
            • Wipe Strip
        • Strip Modifiers
        • Selecting
        • Editing
        • Meta Strips
    • Storyboarding
      • Storyboarding App Template
  • Assets, Files, & Data System
    • Introduction
    • Blender File
      • Opening & Saving
      • Compatibility
      • Packed Data
      • Blend-Files Previews
      • Rename
    • Data-Blocks
    • Properti Kustom
    • File Paths
    • Linked Libraries
      • Link & Append
      • Library Overrides
    • Asset Libraries
      • Introduction
      • Asset Catalogs
    • Media Formats
      • Supported Image Formats
    • Importing & Exporting Files
      • Alembic
      • Motion Capture (BVH)
      • Universal Scene Description
      • Wavefront OBJ
      • Stanford PLY
      • STL
      • FBX
      • FBX (Legacy)
      • Import SVG as Curves (.svg)
      • Export Grease Pencil as PDF
    • Node Wrangler (Pengelola simpul)
    • Rigify
      • Introduction
      • Penggunaan Dasar
      • Bone Positioning Guide
      • Generated Rig Features
      • Creating Meta-rigs
      • Rig Types
        • Basic
        • Spines
        • Limbs
        • Faces
        • Skin
        • Face
      • Feature Sets
    • glTF 2.0
    • Manage UI Translations
    • VR Scene Inspection
  • Advanced
    • Using Blender From The Command Line
      • Launching from the Command Line
        • Linux
        • macOS
        • Windows
      • Arguments
      • Rendering From The Command Line
    • Scripting & Extending Blender
      • Introduction
      • Scripting & Security
      • Add-on Tutorial
    • Creating Extensions
      • Getting started
      • Compatible licenses
      • Supported tags
      • Version Number Guidelines
      • Python Wheels
      • Creating a Repository
        • Static Repository
        • Dynamic Repository
    • Application Templates
    • Keymap Customization
    • Working Limits
    • Operators
    • Blender's Directory Layout
    • Deploying Blender in Production
    • Appendices
      • Rotation Modes
  • Troubleshooting
    • Startup
    • 3D Viewport
    • Graphics Hardware
      • Windows
        • NVIDIA
        • AMD
        • Intel
        • Other GPU
      • Linux
        • NVIDIA
        • AMD
        • Intel
        • Other GPU
      • macOS
        • NVIDIA
        • AMD
        • Intel
        • Other GPU
    • Crashes
    • Network
    • Python Errors
    • Recovering Data
    • Reporting a Bug
  • Glossary
  • Manual Index
Penglibatan
  • Dokumentasi Kontribusi
    • Online Editing
    • Local Editing
      • Menginstal Dependensi
        • Linux
        • macOS
        • Windows
      • Building the Manual
      • Mengedit Manual
      • Pull Requests
    • Memulai
    • Pedoman
      • Panduan Gaya Menulis
      • Panduan Gaya Markup
        • Icons
      • Commit Guidelines
      • Templates
      • Icons
      • Perawatan
    • Documentation Todo List
    • Documenting New Features and Changes
  • Translate Blender
  • Translate the User Manual
    • Contribute
    • Panduan Style
    • Adding a Language
  • Versi
    • Sedang memproses...
    • Versi Lama
  • Bahasa
Back to top
Edit this page
Dynamic Paint Modifier¶
The Dynamic Paint modifier is a container for a Dynamic Paint Physics simulation.
Options¶
As the modifier is only a container its actual options are configured in the Physics Properties tab. See the Dynamic Paint Physics Properties for more information.
Next
Explode Modifier
Previous
Collision Modifier
Made with Furo
Last updated on 2026-06-09
  • View Source
  • Lihat Terjemahan
  • Laporkan isu pada halaman ini
On this page
    • Options
