Referensi
Panel:
Render ‣ Grease Pencil
This panel contains settings that control the rendering of Grease Pencil lines.
Viewport
SMAA Threshold
Threshold for the edge detection algorithm used to correct aliasing for the 3D Viewport, Higher values may result in loss of detail due to excessive blurring.
Render
SMAA Threshold
Threshold for the edge detection algorithm used to correct aliasing for the final render, Higher values may result in loss of detail due to excessive blurring.
SSAA Samples
Number of samples used for super-sampling anti-aliasing in the final render. Higher values produce smoother lines but increase render time.
Motion Blur Steps
Controls accuracy of motion blur, more steps result in longer render time. Only used when Motion Blur is enabled. Set to 0 to disable motion blur for Grease Pencil objects.
