Split Edges Node¶
Like the Edge Split Modifier, the Split Edges node splits and duplicates edges within a mesh, breaking 'links' between faces around those split edges.
Inputs¶
- Mesh
Standard geometry input.
- Selection (Seleksi)
A standard Boolean selection input to determine which edges will be split.
Catatan
Because of mesh topology requirements, sometimes more or fewer edges than are selected will be split.
Outputs¶
- Mesh
Standard geometry output.
