Vector Rotate Node¶
The Vector Rotate Node provides the ability to rotate a vector around a pivot point (Center).
Inputs (Inputs)¶
- Vector (Vector)
Vector to be rotated.
- Center (Middelpunt)
Point to rotate around.
- Axis (As)
Axis to rotate around.
- Hoek
Angle to rotate the input vector by.
- Rotation (Rotatie)
When Type is set to Euler, rotate the input vector by these angles around the X, Y, then Z axes in that order.
Properties (Eigenschappen)¶
- Type (Type)
The type of angle input.
- X/Y/Z Axis:
Rotates the vector around the defined axis and the amount of rotation is defined by the Angle input.
- Axis Angle (Rotatiehoek):
Rotates the vector around an arbitrary axis defined by the Axis input vector. The amount of rotation is defined by the Angle input.
- Euler:
Rotates the vector about a center point defined by the Center input vector. The amount of rotation on each axis is defined by the Rotation input vector.
- Invert (Omkeren)
Inverts the rotation angle.
Outputs (Outputs)¶
- Vector (Vector)
The rotated vector.
Examples (Voorbeelden)¶
Vector Rotate node example.¶
