Edge Neighbors Node¶
The Edge Neighbors node outputs topology information relating to each edge of a mesh.
Inputs¶
This node has no inputs.
Outputs¶
- Face Count
The number of faces that use the edge as one of their sides. When the value is one, the edge is a non-manifold boundary edge. Alternatively, when the value is zero, the edge is a loose edge, not used by any faces.
Beispiele¶
Using the Face Count output to create a curve on a mesh’s boundary edges.¶
