XPBD Solver¶
The XPBD Solver node provides a physics simulation system for hair, cloth, and particles. It implements the „extended position-based dynamics“ (XPBD) procedure.
This node is used in the Hair Dynamics and Cloth Dynamics experimental node assets.
The node expects data to be provided in the form of Typed Bundles through its World input. This includes both the simulated geometry components, structural constraint declarations targeting the geometry, and external effectors such as damping and collision.
The XPBD Solver node is complex and intended to used inside more user-friendly assets. Full documentation of its behavior and supported components of the World input can be found in the developer documentation
Inputs¶
- World
Bundle of geometry, behaviors, and effectors making up the simulation. Bundles can be nested inside each other; the world data does not have to follow any particular structure. Geometry and effectors can be grouped into logical sub-bundles, or kept in a flat bundle.
- Delta Time
Size of the overall time step in seconds. The step size is subdivided if a Substeps value greater than 1 is used.
- Filter
Comma-separated list of filter tags to limit which geometries are being simulated. Each geometry may be associated with list of tags, and the solver node will only simulate geometries that have at least one matching filter tag.
- Simulation to World
Optional transform from object space into simulation space. This defines the space in which all physical simulation takes place. All geometry attributes, forces, and other properties should be transformed accordingly beforehand. Collider geometry is converted to simulation space internally.
Solver¶
- Substeps
Number of substeps used by the simulation. Increasing substeps can help improve stability in some cases, but also increases cost due to repeated collision detection.
- Constraint Iterations
Number of iterations performed by the constraint solver to ensure all constraints are satisfied. If the residual error is larger than 1 then increasing the constraint iterations is recommended.
- Path
Optional output path for solver result data. If the path is not empty a new bundle is added to the World output with the results of the solver step.
Interpolation Range¶
- Begin
Fractional start of the substep interval. This can be used for executing an external substep loop.
- Begin
Fractional end of the substep interval. This can be used for executing an external substep loop.
Outputs¶
- World
Modified simulation data after a single time step has been applied. Geometry attributes for positions and rotations are updated according to physical motion, external forces, and constraints.
Additional information about the simulation result may be stored in a bundle by setting the Path input. This includes a residual error value which describes the quality of the solution.
