Bokeh Image Node#
The Bokeh Image node generates a special input image for use with the Bokeh Blur filter node.
The Bokeh Image node is designed to create a reference image which simulates optical parameters such as aperture shape and lens distortions which have important impacts on bokeh in real cameras.
Входы#
Этот узел не содержит входов.
Свойства#
The first three settings simulate the aperture of the camera.
- Flaps
Sets an integer number of blades for the cameras iris diaphragm.
- Angle (угол)
Gives these blades an angular offset relative to the image plane.
- Rounding (округление)
Sets the curvature of the blades with (0 to 1) from straight to bringing them to a perfect circle.
- Catadioptric
Provides a type of distortion found in mirror lenses and some telescopes. This can be useful to produce a visual complex bokeh.
- Lens Shift
Introduces chromatic aberration into the blur such as would be caused by a tilt-shift lens.
Выходы#
- Image
The generated bokeh image.
Пример#
In the example below the Bokeh Image is used to define the shape of the bokeh for the Bokeh Blur node.
Пример узла Bokeh Image.#
