Volume Info Node#
The Volume Info node provides information about Smoke Domains.
Входы#
Этот узел не содержит входов.
Свойства#
Этот узел не содержит свойств.
Выходы#
- Color
Gives the color of the smoke inside the Fluid Domain. The color and vector outputs are the same. The Factor output is an average of the channels.
- Density (плотность)
Gives a scalar defining the density of any smoke inside the Fluid Domain.
- Пламя (Flame)
Gives a scalar defining the density of any fire inside the Fluid Domain. All three outputs are the same.
- Температура
Gives a scalar defining the temperature of the volume. Values in the range 0 - 1 map to 0 - 1000 kelvin. This may be used to render physically-based fire with the Blackbody or Principled Volume shaders. All three outputs are the same.
Пример#
Smoke density.#
Computing the color of fire using the Blackbody node. Since the Blackbody node expects its input in Kelvin, the temperature output has to be remapped first.#
