Animation Editors¶
Blender provides a set of editors designed for creating, editing, and refining animation. These editors let you work with keyframes, curves, non-linear actions, drivers, video sequencing, and motion tracking as part of the animation pipeline.
Each editor serves a different purpose:
The Dope Sheet organizes and manipulates keyframes across multiple objects and data-blocks.
The Graph Editor provides fine control over F-Curves to refine motion and interpolation.
The Nonlinear Animation (NLA) Editor arranges and layers animation actions for complex sequencing.
The Drivers Editor links properties with expressions for procedural animation.
The Movie Clip Editor supports motion tracking, mask editing, and stabilization, which can be integrated into animation and compositing workflows.
The Video Sequence Editor (VSE) combines rendered animations, image sequences, audio, and effects into a final movie edit.
Together, these editors form the backbone of Blender’s animation system – from quick keyframe adjustments to advanced rigging, motion editing, visual effects integration, and final shot assembly.
This page describes features that are shared across the different animation focused editors.
Playhead (Speelkop)¶
Playhead (Speelkop).¶
De Playhead is de blauwe verticale lijn die het huidige framenummer aangeeft.
It can be moved to a new position by clicking or dragging LMB in the scrubbing area at the top or by click and drag Shift-RMB anywhere in the timeline.
While dragging it can snap to elements of the editor in which it is dragged. - Seconds - Frames - Markers - Strips - Keys
It is only possible to snap to elements that are visible in the editor in which the playhead is dragged. For example having “Strips” enabled but dragging in the Graph Editor will do nothing. Snapping can be toggled during scrubbing by holding down Ctrl.
Snapping to seconds or frames can have a custom increment for example snapping to every third frame. This is always relative to the first frame of the scene and ignores the preview range. In contrast to the other snapping options, seconds and frames will always snap to the closest position, regardless of the snap distance set. When mixing options, the system will first try to snap to elements that are snapped by distance. Only if no element is close enough will it snap to seconds or frames.
You can also move it in single-frame increments by pressing Left or Right or Alt-Wheel. To jump to the beginning or end frame (of the ends of the preview range if that is active) press Shift-Left or Shift-Right.
Snapping (Magnetisch Uitlijnen)¶
Reference (Referentie)
- Menu:
Playhead snapping helps you position the playhead precisely when scrubbing the timeline by snapping it to specific elements like frames, markers, or keyframes.
- Use Snapping
Enables or disables snapping behavior when moving the playhead.
- Snap Distance
The maximum distance (in pixels) the playhead can be from a target before snapping to it.
- Snap Target
Specifies which elements the playhead can snap to:
- Frames (Frames):
Snap to frame intervals.
- Seconds (Seconden):
Snap to second intervals.
- Markers (Markeringen):
Snap to timeline markers.
- Keyframes (Keyframes):
Snap to animation keyframes.
- Strips:
Snap to the start and end points of strips (e.g. in the Video Sequencer).
- Frame Step Frames
The interval in frames between each snap point when using the Frames target.
- Second Step Seconds
The interval in seconds between each snap point when using the Seconds target.
Playback Controls¶
The Playback Controls region of the animation editors (such as the Timeline, Dope Sheet, Graph Editor, and NLA Editor) contains controls and options related to playback, keying, auto keyframing, and transport.
These settings allow you to:
Control how animations are previewed and synchronized with audio.
Insert and manage keyframes through keying sets and auto keying.
Navigate the timeline using playback and transport controls.
Adjust frame ranges and preview specific segments of the animation.
The footer is shared across animation editors to provide a consistent workflow for animators, whether they are editing keyframes, adjusting curves, or sequencing actions.
Playback (Afspelen)¶
Properties for how animations are played.
- Sync
3D Viewport red FPS.¶
Als de animatie-afspeelsnelheid niet kan bijhouden met de gewenste Frame Rate, wordt de werkelijke framerate (weergegeven in de linkerbovenhoek van de 3D Viewport) rood, en de Sync optie bepaalt hoe de situatie moet worden afgehandeld.
- Play Every Frame (Speel Elke Frame):
Speel elke frame af, ook al resulteert dit in een langzamere afspeelsnelheid dan bedoeld.
- Frame Dropping:
Drop frames als de afspeelsnelheid trager wordt dan de framerate van de scène.
- Sync to Audio (Synchronizeer met Audio):
Drop frames als de afspeelsnelheid te traag wordt om gesynchroniseerd te blijven met audio.
- Audio – Scrubbing
Speel stukjes van de audio in de animatie af (indien aanwezig) terwijl de Playhead wordt verplaatst.
- Audio – Play Audio
Vink uit om al het geluid te dempen.
- Playback – Limit to Frame Range
Sta niet toe de Speelkop buiten het Framebereik te verplaatsen met de muis.
- Playback – Allow Preroll
Allows playback to continue before the Start Frame.
This is useful when starting playback from outside the scene frame range, such as when scrubbing earlier frames or previewing motion that leads into the defined frame range.
This option is disabled when Limit to Frame Range is enabled.
- Playback – Follow Current Frame
Pan de weergave automatisch om de Speelkop in te halen wanneer deze uit beeld gaat.
- Loop
Defines what happens when playback reaches the last frame.
- Infinite:
After the last frame, playback jumps back to the first frame and continues playing indefinitely.
- Stop at End Frame:
Playback stops when the last frame is reached.
- Stop at Start Frame:
After reaching the last frame, playback jumps to the first frame and stops.
- Restore Frame:
After reaching the last frame, playback stops at the frame where playback originally started.
- Bounce (Stuiter):
When the last frame is reached, playback reverses direction.
- Play In
Welke editors bijgewerkt moeten worden bij elk animatieframe. Als een editor niet is aangevinkt, wordt deze alleen bijgewerkt wanneer het afspelen stopt (met enkele uitzonderingen waarbij de editor toch bij elk frame wordt bijgewerkt). Wanneer afspelen wordt gestart in de Graph Editor, Dope Sheet of de NLA Editor, zullen alle editors afspelen, ongeacht de instellingen. Dit is een functie die door animators is gevraagd om gemakkelijk alle weergaven af te spelen.
- Show – Subframes
Toon en stel het gebruik van fractionele framewaarden in voor het huidige frame in.
- Set Start/End Frame (Stel het Start/Eind frame in)
Stel het start-/eindframe van de scène in op het huidige frame. Als het Preview Range actief is (zie Frame Controls), wordt die in plaats daarvan aangepast.
Keying¶
De Keying popover bevat opties die van invloed zijn op het invoegen van keyframes.
Notitie
The name of this popover will change depending on the active keying set.
- Active Keying Set (Geselecteerde Keying Set)
Timeline Keying Sets.¶
Een Keying Set is een genummerde verzameling van animeerbare eigenschappen. Als men er een selecteert en vervolgens I indrukt zonder over een invoerveld te zweven, zal Blender keyframes maken voor de eigenschappen in die keying set.
Als men geen keying set heeft geselecteerd, zal in plaats daarvan keyframes voor een standaardset van eigenschappen worden gebruikt (bijvoorbeeld Locatie/Rotatie/Schaal voor objecten).
Er zijn een aantal vooraf gedefinieerde keying sets, maar ook eigen keying sets kunnen gemaakt worden in het Keying Sets paneel.
- Voeg keyframes toe Alt-I
Voeg keyframes toe op het huidige frame.
- Verwijder keyframes Alt-I
Verwijder keyframes op het huidige frame.
- New Keyframe Type
Het keyframe type voor nieuw aangemaakte keyframes.
- Cycle-Aware Keying
Bij het invoegen van keyframes in trivially cyclic curves, wordt speciale behandeling toegepast om de integriteit van de cyclus te behouden (meest nuttig bij het aanpassen van een gevestigde cyclus):
Als geprobeerd wordt een keyframe in te voegen buiten het belangrijkste tijdsbereik van de cyclus, wordt het teruggeplaatst binnen het bereik.
Wanneer één van de eindkeyframes wordt overschreven, wordt de andere dienovereenkomstig bijgewerkt.
Bovendien, wanneer een nieuwe curve wordt toegevoegd aan een actie met een Manual Frame Range en Cyclic Animation ingeschakeld, wordt de curve automatisch cyclisch gemaakt met een periode die overeenkomt met het framebereik. Voor gemak wordt deze controle en conversie ook uitgevoerd voordat de tweede keyframe aan zo’n curve wordt toegevoegd.
Auto Keying¶
Auto Keying button.¶
Wanneer de opnameknop () is ingeschakeld, zal Blender automatisch keyframes aanmaken op het huidige frame telkens wanneer men een object of bot in de 3D Viewport transformeert (of één van zijn transformatie-eigenschappen wijzigt in de Properties Editor).
Een speciaal gebruiksgeval is het opnemen van een cameratraject terwijl men door de scène vliegt. Zie Fly/Walk Navigation.
Notitie
Auto Keying werkt alleen voor transformatie-eigenschappen (Locatie, Rotatie, Schaal). Het zal geen keyframe aanmaken als men bijvoorbeeld de kleur van een materiaal wijzigt — dat moet nog steeds handmatig worden gedaan.
- Mode (Modus)
- Add & Replace:
Voeg keyframes toe of vervang ze indien nodig.
- Replace (Vervangen):
Vervang alleen bestaande keyframes.
- Only Active Keying Set (Alleen de actieve Keying Set)
Standaard zal Auto Keying keyframes aanmaken, zelfs voor eigenschappen die niet in de active keying set staan. Gebruik dit selectievakje om dat te wijzigen.
- Layered Recording (Laagsgewijze opname)
Voegt een nieuwe NLA Track toe voor elke doorgang over de animatie, zodat niet-destructieve aanpassingen mogelijk zijn.
Transport Controls¶
Deze knoppen worden gebruikt om het huidige frame in te stellen en de afspeelsnelheid te regelen.
Transport controls.¶
- Jump to Start Shift-Left
Stelt de speelkop in op het begin van het framebereik.
- Jump to Previous Keyframe Up
Verplaatst de afspeelkop naar het vorige keyframe.
- Rewind Shift-Ctrl-Spacebar
Begint de animatie achterstevoren af te spelen.
- Play Spacebar
Begint de animatie af te spelen.
- Pause Spacebar
Stopt het afspelen van de animatie.
- Jump to Next Keyframe Down
Verplaatst de Speelkop naar het volgende keyframe.
- Jump to End Shift-Right
Stelt de Speelkop in op het einde van het framebereik.
- Jump Backward by Delta Ctrl-Left
Jumps the playhead backwards by a user-configured delta.
- Jump Forward by Delta Ctrl-Right
Jumps the playhead forward by a user-configured delta.
Additionally, there is a menu accessible to the right of the Jump by Delta buttons where their delta can be set:
Frame Controls¶
- Current Frame Alt-Wheel
Het nummer van het frame dat momenteel wordt weergegeven in de 3D Viewport. Dit is ook de locatie van de Speelkop.
- Use Preview Range
Het Previewbereik is een alternatieve framebereik die men kan gebruiken om te concentreren op een specifiek deel van de animatie. Het stelt in staat om herhaaldelijk een kort segment af te spelen zonder handmatig terug te spoelen of het framebereik van de gehele scène te veranderen.
Dit bereik heeft alleen invloed op de preview in de 3D Viewport; het heeft geen invloed op het renderen.
De grenzen van het Previewbereik worden weergegeven in donkeroranje. Men kan het snel configureren en inschakelen door P in te drukken en een vak te slepen. Om het uit te schakelen, kan Alt-P worden ingedrukt.
- Start, End
Het start-/eindframe van de scène (of het previewbereik, als dit actief is).
