In-Betweens
../_images/animation_armatures_posing_editing_in-betweens_tools.png
In-Betweens Tools.
These tools create a new pose which is based on the keys surrounding the current frame. This can help to quickly build up in-betweens from already existing key poses.
Blend Pose with Rest Pose
Reference (Referentie)
Mode (Modus):
Pose Mode and Object Mode
Menu:
Pose ‣ Animation ‣ In-Betweens ‣ Blend Pose with Rest Pose
Menu:
Object ‣ Animation ‣ In-Betweens ‣ Blend Pose with Rest Pose
Blend with Rest Pose linearly interpolates the current pose to the rest position. When blending with a negative factor, the pose is moved away from the rest position. Only one keyframe is needed for this tool unlike two for the other.
Push Pose from Breakdown
Mode (Modus):
Tool (Tool):
Toolbar ‣ In-Betweens Tools ‣ Push
Menu:
Pose ‣ Animation ‣ In-Betweens ‣ Push Pose from Breakdown
Menu:
Object ‣ Animation ‣ In-Betweens ‣ Push Pose from Breakdown
Shortcut (Sneltoets):
Ctrl-E
Push Pose interpolates the current pose away from the linear interpolation between the surrounding keys. On your current frame, imagine a pose that is linearly interpolated from the surrounding keys. That is the base pose that this tool interpolates away from.
Relax Pose to Breakdown
Mode (Modus):
Tool (Tool):
Toolbar ‣ In-Betweens Tools ‣ Relax
Menu:
Pose ‣ Animation ‣ In-Betweens ‣ Relax Pose to Breakdown
Menu:
Object ‣ Animation ‣ In-Betweens ‣ Relax Pose to Breakdown
Alt-E
Relax Pose is the opposite of Push Pose from Breakdown. Hence at full influence, the resulting pose will be identical to a linear interpolation between the surrounding keys.
Pose Breakdowner
Mode (Modus):
Tool (Tool):
Toolbar region ‣ In-Betweens Tools ‣ Breakdowner
Menu:
Pose ‣ Animation ‣ In-Betweens ‣ Pose Breakdowner
Menu:
Object ‣ Animation ‣ In-Betweens ‣ Pose Breakdowner
Shift-E
Creates a suitable breakdown pose on the current frame.
The Breakdowner tool can be constrained to work on specific transforms and axes, by pressing the following keys while the tool is active:
  • G, R, S: move, rotate, scale
  • B: Bendy bones
  • C: custom properties
  • X, Y, Z: to the corresponding axes
Blend to Neighbor (Blenden naar naburige)
Mode (Modus):
Menu:
Pose ‣ Animation ‣ In-Betweens ‣ Blend to Neighbor
Menu:
Object ‣ Animation ‣ In-Betweens ‣ Blend to Neighbor
Shift-Alt-E
Transitions the current pose with the neighboring keyframes in the timeline. In order for this operator to work, there must be a keyframe before and after the current frame.
