Is Spline Cyclic Node¶
The Is Spline Cyclic controls whether each of the curve splines start and endpoints form a connection.
Its output corresponds to the built-in cyclic attribute on the curve spline domain.
The node to set this data is the Set Spline Cyclic Node.
Inputs (Inputs)¶
Deze node heeft geen invoer.
Outputs (Outputs)¶
- Cyclic (Cyclisch)
Whether the spline is cyclic.
