Trim String Node¶
The Trim String node removes specified characters from the beginning and/or end of a string. It does not affect characters in the middle of the string.
This node is useful for cleaning up input data, such as removing unwanted prefixes, suffixes, or extra whitespace.
Inputs (Inputs)¶
- String
The input string to trim.
- Characters
A set of characters to remove from the start and/or end of the string.
Each character is treated individually, and the order does not matter. Any matching characters found at the boundaries of the string are removed repeatedly until a non-matching character is encountered.
- Whitespace
Removes whitespace characters (such as spaces, tabs, and line breaks) in addition to the characters specified in Characters.
Limit (Limiet)¶
- Start
Enables trimming from the beginning of the string.
- End (Eind)
Enables trimming from the end of the string.
Outputs (Outputs)¶
- String
The resulting string after trimming.
