Mesh to Volume Node¶
The Mesh to Volume node creates a fog volumes based on the shape of a mesh.
The volume is created with a grid of the name "density".
Inputs (Inputs)¶
- Mesh (Mesh)
Standard Mesh input.
- Density (Dichtheid)
Value of voxels inside the generated fog volume.
- Resolution Mode
How the voxel size is specified.
- Hoeveelheid:
Specify the approximate number of voxels along the diagonal.
- Size (Grootte):
Specify the voxel side length. It is recommended to be careful when tweaking this value, because small changes can have a large effect on the processing time.
- Voxel Amount Amount
- Voxel Size Size
- Interior Band Width
The maximum distance of the included voxels to the surface on the inside of the mesh.
Outputs (Outputs)¶
- Volume
The generated volume grid.
